Question about Hotpoint Dishwashers
Hotpoint Aquarius FDW20 just the Prewash light is flashing, what does this mean please?
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
  • 183 Answers
SOURCE: flashing lights
Not heating, check element and thermal fuse/thermostate. Regards Advisor
Posted on Aug 31, 2007
SOURCE: hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Posted on Feb 19, 2009
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
  • 4 Answers
SOURCE: wash leaves a white film over dishes and wash / dry lights flash
sounds like you may not be getting enough water.it will stop if water is in short supply.this may be if you are running washer at the same time.or running a bath.if hot water is in short supply,this maybe a hotwater heater problem.have you been running out of hot water when showering or bathing?
Posted on Aug 12, 2009
Dishwasher repair
If this is the first and forth LEDs then i was told by a Hotpoint engineer that this means 'heater cut out due to overheat' and that probably the heater is just covered in limescale. If that is the case then running a descaler through the dishwaer on the highest setting should fix the problem and clean the inside of your machine to boot !
I guess this would happen if your machine is a few years old and you live in a hard water area.
Nov 12, 2013 | Dishwashers
Prewash light flashing
usually means a prob taking in water, check taps, also hoses that there are no kinks
Mar 29, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw20 fault lights
Jan 11, 2009 | Dishwashers
When the washer go s on rinse the prewash flashes Problem
Mine has been doing the same ... each time it goes to the next part of the cycle the red light flashes but the machine doesn't do anything ... so up till I have been able to get the machine moving to the next stage by pressing the "Start" button ... unfortunately the machine will pause on each stage - meaning I have to press "Start" at each stage!
Dec 15, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Dishwashers Logo
224 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
