Question about HP Photosmart C3135 All-In-One InkJet Printer
Green copies i need a service manual to clean ink jet nozzels
  • blacka98 Dec 27, 2008
    I am trying to print pictures and they ome out green!
  • 435 Answers
To visit the manuals page for your printer, please click the below link:
HP Photosmart C3135 Manuals
Thank you
Posted on Jan 07, 2009
I hooked up a canon ip90 printer to my mac book and it does not print black color is ok, the printer was hooked up on a pc for years. i have cleaned the nozzels and when i check the printer does not see...
If your printer is successfully connected to your computer and printing in color you may have a printer hardware problem. You said that the printer software does not show a black cartridge? Have you changed cartridges lately, did the problem possibly start after changing the black cartridge?
Have you completely powered off the computer, including pulling the power cord from the printer to allow the printer software to reset itself.
When you clean the jets, did any black ink show on the printed test page after the cleaning?
Is it possible that you have a bad black ink cartridge or that the tab is still covering the ink jets on the black cartridge.
If none of these issues help solve the problem, you printer may need to be looked at by a qualified service technician.
Please let me know what you have done so far and I will attempt to help your further with more information.
Brian
Jan 08, 2011 | Canon PIXMA iP90 Mobile Printer
2001 vt1100 shadow sabre, 45kmi. Backfires on decel, black soot on rear fender & and tire after 75 mile ride. Will not idle without choke until at running temp. Smells like it's running rich. should I...
Try cleaning the carbs ,could be bad air supply or blocked idle jets .These jets have very small holes and you will need very fine cleaning wires .Nozzel cleaners the type used to clean out oxy / acetylene nozzels are great for this job.
Mar 12, 2010 | 2004 Honda VT 1100 C2 Shadow Sabre
My hp all in one is printing in green. I just changed the black ink, thinking it was out, but that wasn't it. I made a copy and it will copy in black. Why is my prining green?
Your colour ink is either almost out or corrupted. First go to control panel, printers and faxes, right click on the printer, go to properties select, go to avanced settings select the help file and find the maintenance section. clean the print head, nozzels end check. If this does not work, you might have to replace the colour ink
Mar 03, 2010 | Office Equipment & Supplies
Cartridge light blinks
Try cleaning the print head first in the software options on the printer and then lightly with a qtip and alcohol or electronics cleaner. The ink jets sometimes dry up and cause the nozzels to get plugged.
Sep 02, 2009 | HP DeskJet 845c Printer
My HP Photosmart c6150 keeps shutting it's self off and then on. Then there was a message that said pump failed
Check the INK nozzels to see if they are clogged, Use a q-tip /or several to remove the ink in the nozzels, then check the ink jets where the ink makes contact with the paper, and clear them, if the printer hasnt been used in a while the nozzel could be clogged , with dry ink , not allowing the ink to flow. and causing the Pump fail to come on.
Jul 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Epson Stylus C62 Error Red light wont go off
Hi victorarcas
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced (see later). You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C62 Service Manual". You will often find them for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Please rate this solution if it has helped you
Dec 22, 2008 | Epson Stylus C62 InkJet Printer
Epson printer
sounds like your coluer jets are blocked all you need to do is clean them for this you will need a suringe and a bottle of nail varnish remover put the suringe on the top of the nozzels then slowly push suringe you can tell if there clean as it will be easer to push
Feb 24, 2008 | Epson Stylus C66 Inkjet Printer
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
HP Photosmart C3135 All-In-One InkJet Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
