Question about Radio Shack Office Equipment & Supplies
RadioShack EC-3033 calculator.Tips to load external paper.Have not removed back to check blockage.(Does not appear to be one).Removed 2 screws to do so.Are there any more screws.
2 Suggested Answers
cautionflag1
  • 116 Answers
SOURCE: how to install adding machine tape to a radioshack
Here is the link to the instruction book for that calculator. It describes how to install the paper into the machine. The only thing I could recommend different is to fold the lead edge of the paper to a 45 degree angle /| instead of the straight edge the book is recommending. Sometimes there is a small blockage in the feed path and the angled fold will get the lead edge passed it enough for the feed rollers to catch the paper. The blockage usually feeds out with when the edge of the paper clears the rollers. I would try it by the book first then try the folded edge. The only other option would be a middle fold /\ in case the blockage is on the edge you folded from in the first attempt
Link to EC-30333 book
http://support.radioshack.com/support_radios/doc46/46048.htm
Hope that helps
Posted on Jun 13, 2010
Order tape for printing
Lorena, Staples will have it in stock, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Calculator Plain Paper 2 25 150 Pack of 3 Calculator And Cash...
Canon 1904B001AA P23 DH Printing Calculator Staples
How to Load Paper Into Canon P23 DH eHow
Mar 05, 2016 | Canon P23-DHV Calculator
Change batteries
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws
from back case.
3. Remove back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator
components while changing batteries.
5. Install new batteries positive side up, as shown on
diagram inside case.
6. Replace back case, and then replace screws.
7. Press OFF ON ON.
Caution: Dispose of old batteries properly. Do not
incinerate batteries or leave where a child can find
them.
Your calculator cannot hold data in memory when
batteries are removed or become discharged.
Feb 02, 2011 | Texas Instruments TI-30XA Calculator
The screen is black, and won't change or show anything else, but can still be turned on and off.
I had the same problems and non of the standard fixes worked for me. I try clearing the memory, re-loading the OS, removing the batteries overnight, etc. Removing the batteries helped but only for a few seconds and then it went back to a black screen. I removed the grounding shield (open the calculator and remove two small screws and remove the shield). The calculator now works fine without the shield. It appears that the shield was shorting some of the capacitors. You can always put it back if it does not work!
Feb 01, 2011 | Texas Instruments TI-83 Plus Calculator
Directions for changing battery
2. Using a small Phillips screwdriver, remove screws from back case.
Caution: Avoid contact with other calculator components while changing batteries.
5. Install new batteries positive side up, as shown on diagram inside case.
7. Press: [OFF] [ON] [ON].
Caution: Dispose of old batteries properly. Do not incinerate batteries or leave where a child can find them.
Your calculator cannot hold data in memory when batteries are removed or become discharged.
Nov 27, 2010 | Texas Instruments TI-30XA Calculator
Need change battery (LR44) but cant open my HP10S. Yes, I took the 2 screws but I can not open the calculator. Thanks. Klaus
The calculator HP10s has 7 attachments. 4 in sides, 2 in the upper part and one in the lower part. First you need to remove the screws, then you have to push the attachment in the lower part and continue with the ones that are in the sides.
Nov 20, 2010 | HP 10s Scientific Calculator
How to install adding machine tape to a radioshack EC-3033
Hope that helps
Jun 12, 2010 | Casio FR-2650A Calculator
One of the keys on my 12c calculator keeps "sticking" so the number often fails to appear on screen. Any advice please.
Here is a link to one of my earlier posts where I show how to test proper operation of the calculator. I invite you to read it.
Jan 08, 2010 | HP 12c Calculator
Paper shredder jam
Check out this video below. I think it should solve any further paper shredder jam problems.
Jul 18, 2008 | Office Equipment & Supplies
Washer-dryer not emptying
Remove the back pannel ( a whole load of screws i must say )
Then you will see at the bottom on the back of the drum where the filters connects... Remove the clip and check and remove any blockage....
Before opening it is possible to check if a blockage exist is to dicconect the waste pipe from the sink and lay it on the floor... Gravity forces the water to flow to the lowest point.. if no water comes out of the pipe then you definately have a blockage...
Nov 12, 2007 | Hotpoint Aquarius WD63 Front Load...
83 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
Frank Zabroski
Frank Zabroski
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
