Question about Clarke Power Products Clarke 10 Gal. Abrasive Blaster Tank With Automatic Shut Off Valve
How can I obtain a manual for a Clarke Abrasive Blaster SB9008 Thanks Den
2 Suggested Answers
SOURCE: I own i 20 gal. clarke abrasive blaster. My
the cfm stated for the blaster is not correct. it requires at least twice of that stated.
Posted on Jan 20, 2010
Sandblasting
Suggest that you carefully drill out the nozzle to suit your new material size. sand for sand blasting has to be total dry or it will cause blockages
Jul 20, 2013 | Clarke Power Products Clarke 10 Gal....
What air pressure do i use for a clarke sb 9006 sand blaster
There will be a regulator valve on the unit and you can adjust it to do the job in hand ie light ruat/paint --just enough pressure to to the job --- heavy rust --more pressure material--- plastic light pressure--- aluminium more pressure --- steel will handle even more pressure.
Jan 14, 2013 | Clarke Power Products Clarke 10 Gal....
I have a Clarke MIG 130 EN welder, butI lost lthe Instruction manual& need a new one.
Hi and welcome to FixYa, I am Kelly
You can get your manual here: Manual PN 6014530
http://www.clarkeservice.co.uk/manuals/mig_welders/mig110e-160en.pdf
Manual is 290 kb Manual says it is 230VAC?
You may have to call them via this contact data to get a 110V manual:
Clark Power Products, Inc. 10752 N. 89th Place, Suite 104. Scottsdale, AZ 85260.
Phone: (480) 661-8599. Fax: (480) 614-0125
email: sales@clarkpowerproducts.com
Their 1-800 number stopped working in 2009 due to financial reasons.
Hopefully this will help you.
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | Clarke Power Products Clarke 130EN Mig 110...
I have a Clarke Mig 130EN Fan Cooled Welder that is not feeding wire and I can't find anyone local to work on it, nor do I know where to go about finding parts. The only Clarke phone number I found...
Hi:
If you are in the USA, check WWW.Praxair.com for your nearest welding store they will help you, Praxair has more than 1000 retail stores in the USA.
If you can make the motor to work just by by-passing the switch then your problem relies on the gun switch, that's an easy fix.
Just an advice; stop buying clarks, it is pretty defficult to obtain speare parts. Lincoln, Miller, Hobart or any other american machine are easier to find parts and are pretty good welders.
Jun 22, 2011 | Clarke Power Products Clarke 130EN Mig 110...
Need on off switch for clark chopsaw 14" BT1010B
The part number for this switch is BT1010B-74. (per manual)
You will need to contact Clarke here:
http://www.clarkeservice.co.uk/parts.shtml
or email them here:
info@clarkeinternational.com / service@clarkeinternational.com
They do not have on line parts info.
Kelly
May 07, 2011 | Clarke Power Products Clarke 6" Abrasive...
I am trying to obtain 18 gauge brad nails for a clarke air nail gun ,can i use any type of straight 18 gauge brad or do clarke make brads for their own tools
you should not have any problem with using any other brand of nail .18 gauge brad nail are pretty much the same in all brands.
Mar 30, 2011 | Air Tools & Compressors
Is the Clarke CT4022 capable of cutting 3/4" oak. If so, is a special bit required.
Hello. Yes the spiral cut-out saw can handle 3/4" oak. Clarke also states that it is compatable with Rotozip bits. I would suggest one of the more aggressive profile sabrecut bits.
Thank you and don't forget to rate us.
Jan 31, 2011 | Clarke Power Products Clarke 6" Abrasive...
I own i 20 gal. clarke abrasive blaster. My problem is that i can only blast for about 30 seconds and then have to wait almost 2 minutes for the pressure to build back up
Sounds like your compressor doesn't have the cfm to keep up with the blaster. Blasters use a lot of air. The cfm of your compressor should match or exceed the cfm of the baster. Try a bigger compressor.
Good Luck!
Aug 20, 2009 | Clarke Power Products Clarke 10 Gal....
Sand Blaster: air shot out of water trap.
1. do you have an adequate air compressor, meaning can deliver sufficient air supply to the sand blaster. 2. if you have an air leak at the water trap at the bottom of the trap it self. you need a new one. 3. it is a must to have a water trap when using a sand blaster.
So what I would do is replace the water trap and install the new water trap at the compressor between the compressor and the air hose coupling. the reason for this is your less likely to have it fail at the compressor VS at the sand blaster. once you have done that. you need to make sure that you have no more than 3/4 of media / sand in the sand blaster itself.
then open air supply valve #1 where the water trap is or was a 1/4 -1/2 way. then open the mid way valve#2 1/4 - 3/4 way. and the bottom valve#3 open 1/4 - 3/4 way. getting the air supply valves all set correctly is hard to do some times.
Air valve #1 supplys the air to the blaster.( more air the better)
Air valve #2 supplys the air going into the top of the blaster tank. ( wich pressurizes the top of the tank to push the sand or media downward )
Air valve #3 supplys the air mixture to sand at the bottom of the tank.
Mar 20, 2017 | Clarke Power Products Clarke SB9008 10...
Clarke Power Products Clarke 10 Gal. Abrasive Blaster Tank With Automatic Shut Off Valve Logo
134 people viewed this question
Top Clarke Power Products Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Clarke Power Products Tool and Hardware - Other Expert? Answer questions, earn points and help others
