Question about Milwaukee Tool Milwaukee 544621 Sdsmax Demolition Hammer
Milwaukee Demolition Hammer #5332. I get only intermittent contact between the striker and the bit. It is annoying to say the least. Seems like lifting the hammer and reseting the bit sometimes will engage the bit. I have cleaned and lubed as required in the manual.\r\n Thoughts?
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: my milwaukee 5316 rotary hammer drill wont
Could be a couple things, do you have the selector in the rotation mode, also there is an internal clutch that might have broken or the splines on the spindle might be rounded. If it is the clutch you would have to take it in for repair, it is extremely tricky to work on. Take the bit out (make sure you are using the right bits for this tool) and look at the splines to check their condition. Let me know if I can help more
Posted on Aug 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need a parts manual for a milwaukee 5316-21
go to Milwaukeetools.com and under service/parts type in your model number and you can download a manual and parts breakdown. Let me know if you need more assistance.
Posted on Feb 12, 2010
rowdy45176
  • 2176 Answers
SOURCE: milwaukee 5338 breaker hammer stopped
my first question is what did the old brushes look like, was the spring burnt, were the contact faces on the brushes not the same. I would make sure that the brushes move freely in the tubes allowing contact with the armature, to ensure this use your volt ohms meter and place one in at a time and check by inserting your probe on the commutator thru the opposite brush tube and the top of the installed brush. I assume you have one if you indicate the cord/switch are OK. If they were not burnt then the next thing I would look for is a loose connection or broken wire from the vibration of this tool. You can get a breakdown and wiring schematic by going to milwaukeetool.com. I strongly recommend doing this before further disassembly. Let me know
Posted on Aug 02, 2011
rowdy45176
  • 2176 Answers
SOURCE: i want to repair cable on a milwaukee hammer drill 5392-1
If you mean the cord you can find the part number by going to milwaukeetool.com and you will need the serial number for the correct one. Or you can also go to ereplacementparts.com. You will need to solder the wire ends to push into the swiitch. To release the old cord straighten one leg of a paper clip and insert next to the wire and gently pull out the old cord. UNPLUG tool first and make note of where the wires came from. The Milwaukee site also has a wiring diagram that you can download. Let me know if you need more assistance.
Posted on Mar 17, 2012
Milwaukee demolition hammer when you pull the trigger it starts full rpm then with trigger still on slows right down anyone know what this might be thanks
RPM magnet which is at the bottom of the electric armature seat is loose and fused in the lower bearing seat of the motor enclosure try to do this with a small screwdriver and make the surface smooth again from the motor housing where small witplastic magnet a very tight space free to rotate, order a new magnet BUT make sure he is glued with a good glue and dried before reassembeld Milwaukee has often into trouble here.
I'm pretty sure that you have a rotary hammer 500 S GOOD LUCK ! position 1236 MAGNETIC DISC (1) 4931426570 by us in Netherlands could be an other number in the states .
Oct 27, 2015 | Hammering
Bosch demolition hammer wont hammer
MUCH NEWER BOSCH demolitionhammers have a special consumables kit you MUST use anyway its marketing technical made exactly on the calculated operating hours.
Every tools has his own kit and by the heavier models of powertools a very special lubricating oil instead of grease that was used by the older tools that are working with a slower tapping block instead of a very fast battle piece.
Apr 12, 2014 | Bosch Hammering
Need diagram for kango 900 concrete hammer drill
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
May 19, 2012 | Milwaukee Tool Hammering
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Dewalt d25940k is a demolition hammer whith drill too?
No, the D25940K is not a Rotary Hammer. It is just a Demolition Hammer. (Jack Hammer). You can turn the chuck to adjust how your bit sits but that is it. Follow this link to the manual for this tool. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/581735-00,D25940.pdf
Aug 11, 2009 | Dewalt D25940K Heavy Duty Demolition...
LOOKING FOR A MANUAL & INFO
Milwaukee now owns Kango, unfortunately I believe the 950sv is the old style. Parts are no longer avail. I have about 20 of the breakers. It is really too bad, they were great machines.
Jan 15, 2009 | Electric Demolition Jackhammer
Milwaukee Tool Milwaukee 544621 Sdsmax Demolition Hammer Logo
270 people viewed this question
Top Milwaukee Tool Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milwaukee Tool Hammering Expert? Answer questions, earn points and help others
