Question about HP Pavilion dv5-1002us Laptop PC
MY HP DV5 1002 AU HEATS VERY MUCH.PLZZZZ HELP ME HOW CAN I REDUCE THE HEAT???
  • 2,567 Answers
If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Posted on Sep 29, 2010
  • tehgooddude Oct 02, 2010
    i decreased the core temp by 30 celciues with just using the vacum cleaner on the fan and heat sink :P
How long will it take Rheem solar hot water to heat up
read manual:
http://www.rheem.com.au/Assets/1294/1/Rheemsolarlolineelectric511series.pdf
Usually electric element heats about 20 gallons per hour.
It appears the element is controlled by thermostat and automatically kicks ON when tank falls below thermostat set point..
This will be handy since element will continually heat the circulating water when outside temperatures turn cool... of course it will also be wasteful if thermostat is set high.
Jul 11, 2013 | Water Heaters
I have a laptop hp pavillion dv5 1002 au. which over heats a lot need help?
you must disassembly and clean the heatsink of the laptop. The fan works ok but you must remove the dust from the pipes.
Jun 03, 2012 | HP Pavilion Computers & Internet
How do I set my thermostat so that it doesn't keep going off and leaving me with no hot water .I have a Honeywell digital thermostat.
The problem is not your thermostat. It is the person who told you that your AC would be your sole source of hot water. The purpose of heat recovery is to ASSIST with hot water production and reduce the current used by your water heater. The only time your AC heats your water is when it is working to cool (or if it's a heat pump, cool and heat) your home. Turn your water heater back on and let your AC help keep the water hot. It's not supposed to do it alone.
Mar 19, 2011 | Honeywell Heating & Cooling
I couldn't find web cam driver in my hp g62-253tu notebook. plzzzz.... help me.
IF you have windows 7, try this link http://bizsupport1.austin.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=4282329&prodTypeId=321957&prodSeriesId=4150047&swLang=13&taskId=135&swEnvOID=4063
If not, try this link http://bizsupport1.austin.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=4282329&prodSeriesId=4150047&prodTypeId=321957&taskId=135&swLang=13
Jan 12, 2011 | Computers & Internet
Technics stereo amp over heats trips overload safety. Fan motor is OK but will not turn on to reduce the heat
The fan is controlled by the thermistor which is heat sensitive, if the temperature rises the thermistor resistance drops and activates the fan, if the fan motor is okay then the thermistor is defective, this part is found on the heat sink with the ic very near by.
Dec 30, 2010 | Audio Players & Recorders
I have a delonghi oven. The grill element smokes violently as the element heats up. Does it need a replacement grill element?
no you dont need a new grill its just collecting fats from when you roasting and burning off when you initially heat the grill. if you use the grill more often it wont build up as much. covering the roast can reduce the saturation and perhaps a slightly lower temp will help reduce splattering.
Aug 02, 2010 | Ovens
My HP pavilion dv9500 has failed with a mother board failure. Before I take action I would like to know whether the hp pavilion dv9500 has a history of motherboard faults; if so is there a good URL which...
The DV6000 and the DV9000 have a bad history of failure at the video card. Most of the failures are caused by an overheating issue. The most recent BIOS updates being released by HP have resolved many problems by making the fan run faster and more efficiently to reduce heat. Also when you buy motherboards for these systems, retailers are including small copper plates to put between the heatsink and processor and video chip to help reduce the heat load. Check any forum that mentions the DV6000 and the DV9000 and you will nothing but complaints about the motherboard problems. Most of which were or are out of warranty and consumers told to pack sand by HP support.
Nov 08, 2009 | HP Pavilion dv9500t PC Notebook
1999 jeep cherokee 4.0 HELP!!!
you probaly wanna make sure its stays out of the sun...
Aug 10, 2009 | 1999 Jeep Cherokee
Pc over heats soon as it is tuned on,hp dv4000
Its a common problem for some model of HP laptops dear. remove any screen savers, put proper air circulation, cleaning fan and heat sinks will reduce heat little bit. but not a full solution
Apr 10, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion dv5-1002us Laptop PC Logo
165 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
