Question about Envision H190L Monitor
We have an Envision H190L Wide screen LCD monitor. We always shut down the screen after each use. The screen just went black and will ot turn on. I've disconnected the cable and plug and reconnected with no luck. The screen is only -3- years old. Any comments or useful suggestions would be appreciated.
  • 11,361 Answers
3 years old is about the right time for the caps in the power supply to fail, that will be the first place to look, it can also be the backlight inverter circuits or worst case will be the lamp assmblies.
Read an see the pictures here:
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 29, 2010
Testimonial: "Very useful information. Unfortunately, I don't have the necessary tools to DIY. I wouldn't even want to attempt it......so I may just replace it. TY"
  • chandramukhi Sep 29, 2010
    yes budmrtn is correct pls check the powersupply capacitors
The display does not fill the screen of the monitor. How can I fix this
It depends on the type of monitor you have. Generally you will have a physical menu button on your monitor. Depress this and look for Vertical and Horizontal adjustments using the arrow keys on your monitor. You can stretch the screen all you like to fit the diameter of your monitor.
Nov 19, 2013 | Envision H190L Monitor
Take off stand on envision monitor
look on the back for four screws that hold it on they should be in a square pattern which is the VESA standard.
Nov 17, 2013 | Envision H190L Monitor
How much does it cost to replace scratched screen on envision h190l monitor
if you want to buy the screen only, its just you buy a new lcd monitor. lcd controller and screen display are too much expensive.
Sep 06, 2012 | Computers & Internet
Power problem
Probably the power supply is failing.
Sep 02, 2012 | Envision H190L Monitor
Monitor turns on but black sceen and it puts up a message that says Out of Frequency
There are 2 possible solutions and the first one is that you need to cut down your resolution in your settings.
1. Right click on background screen
2click settings tab
3. Go to bottom left and move the arrow leftand clicck apply
This may fix it.
The next thing is thatsome of the capacittors on your power supply may be bad and need to be replaced.
Feb 16, 2011 | Envision H190L Monitor
I plugged in an Envision Monitor, H190L, to my HP Pavillion a1020n. I get No Signal and then a blank screen. How do I fix this?
Hi
Often there is noting wrong with the display, in most cases the problem is with the computer.
Try the monitor in both of the display outputs your system has, some machines only have one.
If the monitor remains blank on both cases and it works in another computer, then the issue is quite clear that your hp pavilion is not starting up properly, possibly the display adapter has stopped working or similar.
Do you get any beeps from the computer? Have you done any changes to the machine recently? have you tried any other displays with the machine?
If you are in warranty you should get in touch with hp directly to avoid voiding your warranty and get the machine fixed.
If you are outside of warranty, the machine needs to be tested at a professional to confirm the cause of the problem.
Let me know if you need further assistance or if you would like to open up the case of the computer and do some testing. I would expect that you have some experience and know what parts are what, if you don't know anything about the internals of the computer it might be best to just take it to a professional.
Dec 25, 2009 | Envision H190L Monitor
Envision model H190L ser#91077CA000122 cannot change resolution
Mac's a bit differant than windows. To change your screen resolution first change the monitors refresh rate to something like 75 hertz. Than you can change the Screen resolution. Thats how it is done on a windows machine. Than again your Mac might need a video card software update.
Feb 04, 2008 | Gateway FPD2275W LCD Monitor
Envision H190L Monitor Logo
243 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
