Question about Fedders R6DH45X Dehumidifier
Dehumidifier makes a lould clanking sound when the fan spins. I took of the back cover, the fan is not hitting anything, sounds like it is coming from inside the motor.
    Habit-Forming:
  • 156 Answers
Sounds like a bearing went bad. Unplug the unit and grab the fan blades and move them. If they slop around inside the motor, you have bad bearings.
Posted on Sep 28, 2010
Testimonial: "thanks"
Why does compressor continue running, even with dehumidifier turned off?
Hello Bernard, thank you for your post!
I see that you are experiencing an issue with the Frigidaire dehumidifier, FAD704DWD, compressor consistently being on. This could be a possible issue with your control panel or sensor. Since it could be any one of these underlying issues I would suggest contacting the manufacturer for further assistance. Hopefully this information is helpful to you. -Matt
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
How can you tell if the compressor in the dehumidifier is working?
listen for it , compressors have a distinct sound of tiny rocks hitting a pan (that not what's really going on in there ) that fans don't have
most units have a timer function that makes u wait for compressor to come on long after fan starts , so u might have to listen for up to fifteen minutes for it
May 14, 2014 | Kenmore 54501 Dehumidifier
MY DEHUMIDIFIER COMPRESSOR SOUNDS LIKE IT IS RUNNIN BUT, THE FAN WHEN ENERGISED IS TIGHT & WILL NOT RUN. WHEN NOT ENERGISED THE FAN SPINS FREELY. SHOULD i REPLACE THE FAN MOTOR???
Definitely sounds like the thing to do. However, before you do that, try lubricating the fan motor shaft with some light oil (like sewing machine oil). That may free it up.
Jun 28, 2011 | LG LHD65EBL Dehumidifier
Fan not working, outlet is live, product is 6 mos old, located in an indoor swimming pool (endless swim machine) Hi E Dry 100,
If the fan does not operate with the fan switch set "on", there is a problem with the power supply, internal wiring, or the fan itself.
First make sure the dehumidifier is plugged in to a working outlet.
Next unplug the dehumidifier and remove the cabinet cover. Check the internal wiring for loose connections.
Next remove the fan and check that it is able to spin freely (by hand). If it spins freely, it should be replaced. Call the manufacturer at 1-800-533-7533 for parts and instructions.
Feb 22, 2011 | Therma-Stor Hi-E Dry 100 Dehumidifier
Fan runs but does not collect water
It sounds as though the compressor is not running or the machine is low or out of refrigerant.
May 26, 2010 | Maytag M7DH45B2A Dehumidifier
LG LHD65EL Dehumdifier Fan Noise
It sounds like the fan has etached from its hub. This usually is not repairable if that's the case. Replace the fan.
Jul 03, 2009 | LG Goldstar LD65EL Dehumidifier
Frostguard 36 Dehumidifier runs, but collects no water.
unfortunately it sounds as though your refrigerant leaked out. If your compressor is running and no moisture, this is probably the case. What is the temperature of the air coming out?
Jun 20, 2009 | Woods Dehumidifiers
Dehumidifier not dehumidifying ...
Save the old one for parts if you get the same new one but I def. don't reccomend buying this unit again. The reviews are bad. The fan is not covered under the warranty except first year or extented warranty. I spoke with Kenmore & Sears about this to see if coverd under 5 yr. Only compressor,tubing & refrigeration system(see inside of front cover for warranty info.)
Sound more like a sensor/circuit board problem to me since fan is turning. I think the signal determins which setting fan needs via sensor assembly to run. I could be wrong. Justa thought.
Can you def. hear the compressor come on. You can look through grill to see fan spin & the compressor makes a clank/clunking noise/ The fan & compressor should turn same time. Good luck! If you got any info. on my fan problem & you have update or fixed your problem I ccould use some help. Check post for my problem.. Thanks! panfan1
Aug 13, 2007 | Kenmore 54701 Dehumidifier
LD65EL Dehumidifier rumbles and has poor air flow
Sounds like the bearings have failed in the fan motor, & the rotor is rubbing on the stator. You mentioned end play in the shaft, check for cross play. There should be no perceptable cross play, any found indicates a need for a new motor.
Jun 20, 2007 | LG LD65EL Dehumidifier
Fedders R6DH45X Dehumidifier Logo
93 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Steve
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
