Question about Frigidaire FGF337EC Stainless Steel Gas Kitchen Range
The electric clock display and oven control will not work. The gas burners will ignite, but the oven will not light with out the panel
    President:
  • 1,430 Answers
This indicates the ERC Electronic Range Control has failed. First check the key pad. Press each button one at a time. You should feel or hear a click and feel the retraction. If any button is not working the problem is likely in the key pad. If you locate the tech sheet ( somewhere on the stove, usually in the control panel) it may have a ohm check that can be done on the key pad to rule out the key pad. If all seems good the control is at fault. Check to see if you have power going into the control. If you do and nothing is working the control board or ERC needs to be replaced. Here is a link for checking and replacing an oven control. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Posted on Sep 28, 2010
Was adjusting the temperature dial when oven shut down clock is off as well and electric gas lighters for elements not working, what would cause this - I have checked the power supply box and it is fine
clock must be set to correct time or it will hinder proper operation of oven
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 18, 2015 | Ovens
Clock,timer and oven does not work on Kenmore gas Range
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
Oct 04, 2007 | Kitchen Ranges
Control panel and oven do not work
http://www.fixya.com/support/p128384-ge_profile_spectra_jgbp90_gas_kitchen/manual-12815
Mar 16, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Svd48600w clock out can't turn on oven, or down draft fan
see this causes and fix it: God bless you
IGNITER
If your gas oven is not heating, the igniter is the most likely the cause. This is a simple gas oven repair. To check the igniter, remove the storage drawer and the bottom of the oven (only if you are working on the bake burner). Now turn on the oven and observe, from a distance, the burner that is not heating. In a minute or so the igniter should glow red. If not, unplug power from oven. Then unplug the igniter and using your ohmmeter ,check to see if you have continuity between the two wires going to the igniter. If you don't have continuity, replace the igniter. If you do have continuity the igniter is still the likely problem, If you turned on the oven and the igniter did glow red, the igniter still is most likely the problem. This video will walk you through properly testing an oven igniter. You have to have an amp meter to check for sure, but I would not suggest buying an amp meter just to check this because 99% of the time its going to be the igniter. So I suggest just replacing the igniter. For those of you that already have an amp meter, clamp the amp meter on one of the wires going to the igniter then turn on the oven. If your igniter is round, the amp meter should read 2.6 to 3.0. If you have a flat igniter then the amp meter should read 3.3 to 3.6. If the amps are not in this range, the gas valve will not open to release gas to the igniter. To repair this, replace the igniter.
BURNER CLOGGED
This is another simple gas oven repair and it's one thing you may need to check before you change any parts. The burner has a lot of small holes that connect the flame all the way around the burner. If one of these small holes is stopped up, the burner will not light properly. To repair this, simply use a large needle or thin wire to clean each hole out. Note that this is not a very common problem but if this does fix your oven, it will save you a lot of money.
GAS VALVE
If your gas oven is not heating, the gas valve may be your problem. If your igniter isn't bad then the gas valve is the problem. This is a very uncommon failure in most ovens. But this is not a simple gas oven repair and it's best if this is changed by a professional because if the gas valve leaks it can be a major fire hazard and you have to adjust the valve to the kind of gas you are using.
Main Control
This is the last thing to check. If you have no power to the igniter when the oven is turned on the main control is the likely problem. On glowbar style igniters if you have no reading and there is continuity of the igniter replace the main control. On ovens with electronic igniters (these are the ones that click) these ovens have a separate spark control module that sends the power to the igniter. This can be difficult to check but in general if you have no power reaching the igniter the spark module or igniter module (there are many different names for this part) would need replacing.
Jul 20, 2012 | Kitchen Ranges
The electronic display went out on my gas range so I can not start the oven. I can still use the gas burners on the stove, but without the electrical panel I can not start the oven. I checked the wire...
This is often due to loose or corroded connections in the wiring.
Unplug the range.
Open the rear of the control panel.
Remove,then re-attach all wires on the control.
If you see any terminals corroded,clean them with a pencil eraser.
If this does not correct the problem,the clock must be replaced.
Dec 18, 2010 | Frigidaire FGFB75D Gas Kitchen Range
No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Jul 17, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Frigidaire FGF337EC Stainless Steel Gas Kitchen Range Logo
204 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
