Question about Frigidaire FEF366EC 30" Freestanding Self-Clean Electric Range w/ Advanced Bake Cooking System & 4 Radiant Elements: Stainless Steel Kitchen Range
F-10 APPEARS ON THE TEMPATURE SCREEN AND A BEEP STARTS AND WILL SOMETIMES CONTINUE AFTER THE OVEN HAS BEEN TURNED OFF. WHAT PART DO I NEED TO REPLACE?
  • Frigidaire Master
  • 1,711 Answers
F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Posted on Oct 02, 2010
Oven temp not correct
One thing you should know about a gas oven is that they do not keep a constant tempature like an electric oven does. So going by a tempature gauge in the oven can fool you. The way a gas oven works is by "average" tempature. In other words if you take the highest and lowest tempature readings and average them out you will get the actual tempature. For example let's say that you set the oven to 350. Well first it will take about 10 to 15 minutes for the oven to properly pre-heat. Once it is preheated you can listen to the gas burner and watch a tempature gauge(flook meter is best). When the gas burner shuts off the oven tempature will continue to rise. When the oven tempature stops rising then you will take that reading. Then wait for the oven burner to come back on again and watch the tempature gauge. When the tempature gets to it's lowest point and stops then take that reading. Do this several times and then take all the tempature readings and add them together then divide that number by the number of readings you took and that will give you the actual tempature. Within 5 degrees is great but anything over 10 degrees can affect your cooking. This will give you an idea if your oven is out of calibration or not.
There is a calibration procedure. The instuctions are located in the owners manual and can be found here http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-85131.PDF
Just go to the "Thermostat Adjustment" section for the proper calibration procedure.
Jul 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Long beep and continue acer motherboard N1996.
1. Beep codes indicates that there is some problem with your RAM memory sticks installed into your computer motherboard.
2. For detailed information about the beep codes, refer your motherboard user manual as there are different kind of beep notifications for different problems.
3. Try removing the RAM from your motherboard, clean of any dust, replace it back to the motherboard and try starting your system. Repeat the step for atleast 10 times, until your system starts up.
4. If still the problem, persists, try replacing your RAM and try again as this will help us to find out if the problem is with RAM or not.
I hope this is helpful to you.
Please rate the solution provided.
Thanks
Jun 29, 2010 | Computers & Internet
Oven does not maintain a consistent temperature
Is this oven gas or electric? If it is gas then it can be normal to see 30 to 50 degrees difference in tempature. The tempature in a gas oven works on the average tempature. For example: The oven tempature may rise all the way up to 370 degrees. Then the burner will shut off. And then the tempature can drop all the way to 330 degrees. Then take 330 and add that to 370 then divide that number by two and the average tempature will be 350. If your oven is electric then the tempature should be much more consistant but can have a 10 to 15 degree variance. Also the standard oven tempature guage that you put in the oven or even the temp guage built into the oven are not very accurate. We us a Fluke meter with a thermocouple to calibrate an oven. So to check your oven for proper tempature regulation you will first need to let the oven pre-heat for about 15 minutes. Then place the thermocouple in the center of the oven. If the oven is electric the take a temp reading every 5 minutes and average them out. If the oven is gas then you will need to take a temp reading when the tempature reaches it's highest and lowest points. Take at least 5 consectutive readings and average them out. You should get an average within 10 degrees of set temp(350 degrees). If it is off by 35 degrees or less you can usually caluibrate the thermostat back to proper temp. This procedure can be different for each range model. If it is more than 35 degrees off or you are getting irratic readings then the thermostat or thermostat components might need to be replaced.
Mar 16, 2010 | Kitchen Ranges
My ps3 had a serious problem red screen appears on my tv
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings.
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven tempature is 10 to 15 degrees lower than set temp.Can this be adjusted? This is a electric oven. GE Profile Model VZ295971J.
all ovens very sometimes 10-25 degrees +/- depending on the brand..nothing you can, do set the temp a little higher if you know its off.
Jan 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Wolf wall oven error message: RTD Open
RTD is resistence tempature detector. The oven is telling you that the tempature probe circuit is open. The temapture probe may have been damaged due to the self-cleaning cycle or it could just be the wiring harness is loose. You will need to remove the tempature probe and test it with a ohm meter. The average reading should be aroun 1200 ohms at room tempature. If it is testing open or the ohm reading is way off then you will need to replace the tempature probe. If it is testing good then it could be aproblem with the control board.
Dec 19, 2009 | Ovens
The oven starts to beep and flashes F2 when the
the f2 is telling you that the tempature is to high. It could be your control board. I personely would call a tech as its got to do with the contacts on the control board or the door lock. can be several different problems.
Nov 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Fault code f90, door lock light keeps flashing and then the oven beep continuosly.
maximum oven door unlock time exceeded. Check wiring between eoc & door lock micro switch. more likely you need to replace the EOC
May 19, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Frigidaire FEF366EC 30" Freestanding Self-Clean Electric Range w/ Advanced Bake Cooking System & 4 Radiant Elements: Stainless Steel Kitchen Range Logo
166 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
