Question about Toro Garden
Pull cord wont retract on my toro self propelled lawn mower
    Scholar:
  • 150 Answers
Sounds like a spring problem. Remove starter shroud, try pulling it and see if it works. If the spring isn't broke you may have to take another rap on the rope to gain more tension, or spray mechanism with some wd to free it up.
Posted on Sep 28, 2010
I have a toro self propelled 6 hp lawnmower battery and pull start it wont start with battery but will with pull cord
Try to start it using jumper cables to boost it from another battery. If it starts, your battery needs replacing.
May 21, 2015 | Toro Lawn Mower With Toro Power Tools
Toro gts 6.75
you will probably need to replace the tabs that pop and grab the fywheel, the springs should be replaced as well.
Jun 15, 2013 | Garden
Try to pull cord but seems seized on my self propelled lawnmower
Look underneath at your blade - it could be bent and hanging up. If not, remove spark plug and try to pull starter cord. If it won't move then you may have seized the motor and a new mower may be in order.
Hope this helps!!
Nov 16, 2010 | Toro Lawn Mower With Toro Power Tools
Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Nov 08, 2009 | Toro Garden
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Yard Man 21" Mower Pull Cord Won't Retract
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
Jul 16, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
399 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
