Question about IOGear GHD225U80 (DHGHD225U80) 80 GB Hard Drive
I was working with ion External hdd well, the computer of down and reinitiates the computer, when I returned to connect the External again hdd, no longer recognized the computer, cannot see the external disc, I tried in another machine and the external disc does not appear
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Why i cant copy files to hdd external (pqi h567v)?
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or
you might tick one box then return after its finished the first repair then return and tick the second box
you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Aug 29, 2012 | PQI 2.5" Portable External 750g Hard Drive...
I have a SJ25M2 HDD which is not detected by any PC or any USB port. There is no "ding-****" sound on connection. Plz suggest
Interesting solutionI have noticed. I shut down computer, then, connect drive, and turn on computer. Then after computer is up and running works great. BUT!! You should never go to sleep mode on computer without first Safely remove device! And every time you shut down computer you should Safely remove device. If disk fails again, just shut down computer, and connect drive, and start it again...
Oct 09, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Simpletech 120gb extern HD does not respond when plugged in and freezes computer hooked up to
try to plug in to other computer it still freeze there might problem with your external hdd. remove cover on your external hdd remove board ckt controller look for possible burn IC. remove hdd and try connect directly to your desktop if it work, assemble again and observe if still freeze you need to replace board controller.
Apr 10, 2010 | Computers & Internet
External hard drive please helpmalfunctioned when
Well if the Ext. HDD is making any kind of noise like spinning up
and spinning down , or a clicking sound the unit may possibly
never run again , if the unit does boot but is not recognized by
your computer try troubleshooting start first with the power outlet
then the power cord then the data cord , make sure its running
when your computer is turned on , there is only one connection
from an Ext. HDD to the computer and that's its data cord , if its
a 3.5 HDD install it into a PC as a slave to try to recover the data
and never for any circumstances place an OS on your static Ext.
HDD , if your HDD never turns on again there are many services
online who specialize in HDD data recovery , if you attempt it
yourself you'll need a pretty close match HDD , a very clean
room a pair of non-powder latex gloves and some tiny Torx
head drivers , a clicking sound is the pick up heads , a spinning
up and down sound is the motor , if the unit needs to be formatted again you will loose the data that is stored on it
sorry I can only help so much , and troubleshooting is always
the best bet , try taking the enclosure case apart and make sure
everything is connected .
Feb 05, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My compure wont recognize my external hard drive.
check if your external hdd connect to the pc.. cables is important..
Aug 24, 2009 | Computers & Internet
My external Samsung HM120JC 120 GB Hard Drive not responding
Not sure what could be the problem.
There are many issues here.
- Did this drive worked before?
- If it did, was this your boot drive?
- USB cable and connector problems
- How is this connected to the drive?
- Is it in a package that came with the drive complete, or you had to install it?
My two cents... Samsung and other Japanese drives are not that reliable and if it's new, return it and get a Seagate drive. They have five year warranty and much better drives.
Apr 08, 2009 | Computers & Internet
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My SimpleTech Hard Drive has stopped working
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Kind Regards
Andrea
Mar 13, 2009 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
WD External won't connect to MacBook Pro
If the computer switched off before writing to the hdd with a TOC or index file, all your files are there they are not recognised by your computer. You will need recovery software to recover your files.
Aug 01, 2017 | Western Digital Passport WDXML800UE...
IOGear GHD225U80 (DHGHD225U80) 80 GB Hard Drive Logo
107 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
