Question about Kenmore Dishwashers
We've just installed a new to us dishwasher. We've not had one previously so all of the plumming is new for that. When I turn on the dishwasher it seems as if the water is only trickles and it's obvious by the sound that the jet are not turning. What are some things I can check before I have to call out a professional?
    President:
  • 1,430 Answers
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Posted on Sep 28, 2010
    Novelist:
    Champion:
  • 266 Answers
Where you hooked your water up to the dishwasher there is a metal screen and it sounds like it needs to be cleaned. The other problem is the solenoid that turns the water on and off may not be opening all the way and this will cause low water pressure. When you clean the screen you may have to pull it out with a hooked wire made from a heavy paper clip or you may be able to pull it out by using a small flatblade screwdriver and pry the screen out. The screen may get damaged but after cleaning it just pull on its edges to make it as round as possible and push it back into the opening. This is a very common probem. Good luck I hope this was helpful.
How to unlock a plum phone useing a google acount
If the phone has service you can do it by logging into your google account, provided that you have used that account on the phone previously. If not, you'll need to contact the service provider for reset instructions as each model is a bit different.
May 20, 2014 | LG Remarq LN240 rubberize Hard Plastic...
Need to freeze plums asap recipe calls for ascorbic acid is it needed?
not that I've ever heard of,, here,, what you need to get is Jardens fresh fruit , or something along those lines, its citric acid thats used in canning fruit, vitamin C ,, lemme see if I can locate that link I saw some time ago,, http://www.pickyourown.org/peachesfreezing.htm There, click on that ,, it will show you how to freeze plums peaches, etc.. Good Luck
Sep 09, 2011 | Plum Toys
My plum tree starts producing plums they start off green then turn yellow and drop off
Lack of pollination or brown rot could be the cause.They are generally not self-fruitful meaning they need a different plum and often a specific variety for pollination and fruit development. If the plums were not full size and lacked a seed (stone) this was the problem.If not try a general fungicide.
May 13, 2011 | Garden
How do i plum in my dishwasher is it hard
No, just hook up the drain line to your sink drain and run a hose to the dishwasher from a hot water line... now that's easy!!
Usually figure an hour two if the house is a nightmare...
heatman101
Aug 28, 2010 | Beko 24 in. D3731F Free-standing...
My dishwasher won't drain after I installed a new garbage disposal.
Check the drain spout of the disposer where you connected the drain hose from the dishwasher and make sure you`ve knocked out the plug in the spout.
If not, with the aid of a long screw driver and a hammer, or a firm smack with the palm of your hand you should be able to knock out the plug. Then reach in the disposer and remove the plug you`ve just knocked out, reconnect the drain hose for your dishwasher and you should be good to go.
Hope that help`s. good luck.
macmarkus :)
Mar 06, 2010 | KitchenAid Dishwashers
Dishwasher smells has a 'wet dog' smell
its the food and the steam together. its normal.
Aug 23, 2009 | GE Nautilus 24" Built-in Dishwasher
I HAVE A BOSCH SHU5305 DISHWASHER THAT WHEN IT IS TURNED ON IT WILL NOT DRAW WATER FOR THE WASH. IT JUST SITS THERE AND HUMS. HAD A BIT OF WATER FROM THE SINK BACK UP IN THE DISHWASHER AND SPILL OVER ONTO...
If the solenoid valve is humming and calling for water, you probably have a plugged screen in the valve, some you can get to and clean, some you have to replace.
Jan 23, 2009 | Dishwashers
Dishwashers Logo
53 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
