Question about Saeco Incanto Classic Espresso Machine
Close door read out appears
Door is closed, ready to use is on display. try steaming an dclose door appears on display even though door is closed. open and shut door and ready to use is on display. try making a shot of coffee and close door is on display agin with door being closed.
    Sergeant:
  • Saeco Expert
  • 223 Answers
You have a problem with the door alignment and the door switch.. The slightest movement triggers the door switch. You should have someone look at what is causing this issue.
For service on your saeco espresso machine in the New York area: www.cerinicoffee.com
Posted on Jun 02, 2008
Will not run - display 'door open' even though it is closed.
Hi Carole, I understand that you are having problems with your Frigidaire Dryer door. It does appear the message "door open" indicates there is a communication error with the door latch assembly. This can sometimes be reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem is not corrected, consider replacing the Door Latch Assembly. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dryers
When I press start nothing happens then "door" flashes on screen even though the door is definitely closed
have you tried push the door in harder once u have turned it on my grandads old hotpoint washer was like this and wen used to jus push the closed door a liltte and it started
Dec 03, 2011 | Hotpoint Washing Machines
Hello, I replaced a worn out garage door motor with a new craftsman model. The door try's to travel down when the opener is pushed, even though the door is fully closed. I'm no garage door expert, but...
Yes, reread the directions travel needs to be set for both up and down, and MUCH MORE IMPORTANTLY the safety settings must be set. This allows the door to close on a foot and not cause damage....VERY IMPORTANT to set correctly....
Apr 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
Display shows flashing 'door' warning,even though door is closed.....then when door is opened/closed a couple of times display will dissapear and re-appear every 3 seconds or so. Help!
The symbol indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 09, 2011 | Washing Machines
We just moved into a house with a MS150 Mr steam. I turn it on and the display reads 110 for 10 mins then comes up with H2O on the display. What do I have to do? Nothing seems to happen.
Hi my name is Mike with Mr. Steam please give me a call at 1-800-767-8326 and ask for tech support. We will need you model # and SN # that is listed on your unit if you can be by your unit when you call and we will help troubleshoot your unit. In the mean time check the following 1) water is on 2) drain valve closed even if you have a auto flush close manuel valve for testing
Thanks
Mike Nail
Mr. Steam
Sep 18, 2010 | Mr Steam MrSteam MS150E Steam Generator
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
MICROWAVE WILL NOT HEAT. F9 APPEARS IN THE DISPLAY WINDOW
F9 indicates a problem with the door latch.  There is a safety switch that will not allow the microwave to operate if it detects the door is not closed properly.  Even though physically it may seem the door is shut, the safety switch is not relaying the message to the onboard computer.  You need another door latch switch.
Mar 10, 2009 | Kenmore 63663 Microwave Oven
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Display reads "not ready"
Try re-opening the handle all the way, then re-closing it.
Oct 09, 2008 | Keurig B50 Coffee Maker
Saeco Incanto Classic Espresso Machine Logo
450 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
