Question about Lexmark T644 Laser Printer
My lexmark printer keeps saying that it's got a 243.10 Paper Jam - check tray 3. There is no paper jam. How do we fix this machine
SOURCE: lexmark c510 241 paper jam error
had same trouble with card stock
I read the manual...lo! There are markers on the inside of the feed tray for various media. Complied with these markers, and no more problem. Should work for paper too.
jre
Posted on Feb 27, 2008
d2704
  • 101 Answers
SOURCE: 202 paper jam
try to find paper or peice (bit, partm particle) of paper under back cover.
Posted on Mar 07, 2009
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
thunderbo611
  • 75 Answers
SOURCE: Lexmark T630 paper jam 238 it says check duplex.
in the back
Posted on Jan 26, 2010
  • 86 Answers
SOURCE: hi, my lexmark T640 is saying 202.06 paper jam,
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Posted on Oct 20, 2010
I have a lexmark e238. Keeps showing paper jam light after cleaning rollers even though no paper is in there.
Either paper is moving too slow through the paper path or one of your paper path sensors is not registering. Pull the paper tray out and check to make sure the little plastic sensor is swinging free. That sensor tells when the tray is empty. Follow the paper path thru the printer checking all the sensors to make sure they are "opening" and "closing".
Apr 07, 2015 | Lexmark E238 Laser Printer
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Tried to print and it says remove paper jam and press start, tried that several times, put more paper in, powered off and it stil says paper jam...opened it up and no paper i can see thats jammed..
Jan 06, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
Paper Jam light is on but no paper jam in printer?
Dec 17, 2009 | Lexmark E250d Laser Printer
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
HP 4200 printer paper jam. No paper is jammed
OK, if the printer says jam but no paper inside and prints after you open and close the cover the paper likely never made it out of the tray. Or the machine thinks the page never made it out of the machine.
As far as input check your rollers 1 in the tray and the pick up roller in the machine if you don't have alot of pages on the machine these likely OK.
Next (and this I have found often) check the paper back stop in the tray. This is the guide to set the length of paper. If it is set just a little long the roller cannot catch the edge of the paper. Sometimes the teeth the guide sets in are broken or worn.
The output would be the sensor in the fuser replace fuser.
Hope this helps
Feb 19, 2009 | HP LaserJet 4200 Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
My fax machine/printer is saying i have a paper jam. there is no paper jam. i am looking in and throughout this machine. i need to print important papers on a daily basis. i need my machine fixed or a...
Normally the machines are right about paper jams, no matter how small a piece of paper it is.
Check in feeder tray, open all doors, look under rollers....etc.
Nov 19, 2008 | Lexmark Office Equipment & Supplies
Lexmark T644 Laser Printer Logo
575 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
