Hello, I have a 6 year old Sylvania tube TV that is the red is going in and out. I took a TV/VCR/PC repair class in high school, that was 12 years ago and I do not know where my notes are. I am an engineering student do I do have experience working with electronic, but I am trying to save some time but asking someone with a little more experience troubleshooting this problem. What could be cauing the red to go out in the picture? note: I still am seeing a picture, just without the color red being mixed in to it.
  • 85 Answers
Hi there. i am not familiar with the set you have as im in the uk,but my best bet is a dry joint on the crt base panel.a good re-solder of the whole board may do the trick for you and will not take long,as the average crt base is only around three inches square or so
regards,
steve uk.
Posted on Sep 28, 2010
How to hookup Sanyo DVW-6100 to a Sylvania tv
If the Sylvania tv is a CRT (old style tube tv) you can just use an RCA cable and hook it into the composite video. It will be the cable that has a red, white and yellow connectors on it. The yellow is the video, the red is the right audio and the white is the left audio. Connect ones side of this cable to the output of the DVD/TAPE player and to the input on the TV side.
Sep 04, 2014 | Sanyo DVW-6100 DVD Player/VCR
I need the remote contol code for a sylvania 6313cb 13in. tv/vcr combo
Hello
Universal remote code for Sylvania TV/VCR Combo is:
0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
May 31, 2011 | Sylvania 6313CB 13 in. TV/VCR Combo
I have a sylvania TV it's a year old and when I
Your power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem.....
May 10, 2011 | Sylvania Televison & Video
My Mitsubishi TV is about 12-14 yrs old. The
DLP projection tvs are bulky and have a design flaw in the convergence board the 2 STK convergence ICS alway dies constinely require replacement,if u use about 4 or 5 hours day in and day out.If the old Mitsubishi tv several years since is was repair,u use it alot?If yes,it time to retire it,and buy the refurbish Plama tv.Not,than get the old tv repair.U Know how to solders?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in Convergence problems will see a tutoring video in repairing 2 STK Convergence ICS.
Mar 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Sylvania DV220SL8 won't play DVDs, DVD tray won't open
One simple solution is to unplug the unit for 30 seconds then plug it back in. Worked like a charm for me.
Jan 09, 2010 | Sylvania DV220SL8 DVD Player/VCR
Sony kp-65w5500 rear projection TV red tube needs replacement
there is a company called Video Display Which sells rebuilt tubes
Jan 19, 2009 | Sony KP-57WS500 57" Rear Projection...
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Sony KV-32S40 32" TV problem
intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Dec 27, 2006 | Sony KV-32S40 32" TV
Tv has bad blue crt (pix tube) said the repairman
If you have a service manual or the experience to do this then I guess you can repair it. You do need a cross hatch generator to do an alighnment and sometimes an ocilliscope to adjust horizontal alighnments as per the service manual. Your paying for what the man took years to learn as repairing TV sets is not an overnight thing. As to the worth its up to you, do you wantt to invest this much money in a set that cost you a bundle?? How old is it? will answer your Question as they usually "made" to go for at least 5 to 7 years. After that its a crap shoot and if its older I wouldnt invest a dime in it. Unless you know how to repair it I would say buy a new one as the other tubes may go out a week from now or it could be 3 years from now as we TV techs are not fortune tellers. Good Luck
Aug 24, 2006 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
