Question about Stoves Kitchen Ranges
I have a Stoves 905MF double electric oven. Tonight all the displays are active with all 8's showing in the temperature and time digital displays and multiple icons showing in the two oven displays. It is also making a rapid clicking sound and flickering. Cycling the power has made no difference.
Re: Stoves 905Mf , I have exactly the same problem, Stoves told me niether power pcb or control pcb available as unit is obsolete.
This oven was made in 2006, what rubbish service !
Posted on Oct 21, 2010
Digital display is higher than actual temperature on oven
there is a thermal probe in the oven to the dispay controler it is a comm.problem on this unit,replace it and it should be fine,
Mar 17, 2014 | GE JTP48 Electric Double Oven
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
Oven temperature is inaccurate and takes a long time to heat to proper temp. I have replaced thermostat with no improvement.
To Adjust the Thermostat
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 12, 2011 | GE J2S968SHSS Dual Fuel (Electric and Gas)...
Stoves 444445060 user manual needed how does the timer work
I don't know what model oven this relates to, STOVES may be able to help you if you need to take this further. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Mar 14, 2010 | Stoves 720EF Electric Double Oven
How do you set the clock on a stoves 059040411 oven?
Nov 01, 2009 | Stoves 720EF Electric Double Oven
Stoves 700ER Oven
Digital Vault access granted, you should receive access details shortly.
Jun 16, 2009 | Stoves 720EF Electric Double Oven
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Feb 22, 2009 | Stoves 720EF Electric Double Oven
How does the q900 works
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Feb 11, 2009 | Stoves Premier 720GRa Gas Double Oven
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370┬░ F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
Kitchen Ranges Logo
345 people viewed this question
Top Stoves Kitchen Ranges Experts
paulcarew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
