Question about Canon PIXMA MX310 All-In-One Printer
I just purchased a DELL Inspiron .. running Windows 7. It says if I just plug in my Cannon MX 310 Printer/Fax that Windows will recognize it and set it up for me. I see that it definitely creates an entry in the printers but I cannot print to this printer .. the job logs and then apparently prints but the print out never comes. Behavior is that everything is working correctly but these print outs are definitely not going to my default printer. Any suggestions?
    Problem Solver:
  • 15 Answers
I am sure that, you have not installed the drivers of that printer, because Windows 7 recognize most of the printers automatically however the printer and fax machine would start working properly the time you would install the printer drivers on your system and laptop, please let me know it works or not, so i can send you next update on it
Posted on Sep 28, 2010
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 28, 2012 | Dell Computers & Internet
New Dell Inspiron 560 with old cannon printer i550. Can a serial adaptor to bus let printer work with printer. I have orig cannon software
You will need a Serial to USB converter dongle that you can buy from a local shop as Dell Inspiron 560 does not have serial ports. Also your disc with the printer driver will not work as it must have got drivers for Windows XP on it and as I assume this is a new computer then it will have Windows 7 operating system.
You can download the drivers from:- http://canon.driversdown.com/Canon-driver-list/s_355_1.shtml
Thanks. If this was helpful then kindly rate me.
Oct 28, 2010 | Computers & Internet
Is it possible to get the disc to install the Cannon Pixma MX310
http://www.soft82.com/download/windows/canon-pixma-mx310-all-in-one-driver/
just go to this link and clilck where it says "free download" at the top, this will install the driver on your computer, you don't need the disc. Hope that's what you were looking for.
Jul 28, 2010 | Canon PIXMA MX310 All-In-One Printer
I have just purchased a dell inspiron with window 7 64 bit and i can't connect the Cannon Imageclass D880
what error is it displaying, plz check weather your printer is windows 7 compatible or not.
Mar 19, 2010 | Canon imageCLASS D880 All-In-One Laser...
Installing a driver for a BJC-85 on a Dell Laptop running Windows 7 32 bit
There is no Windows 7 driver planned as this printer is obsolete on the cannon website.
It does not even support windows XP or Vista, only up to Windows 2000.
Mar 07, 2010 | Dell Inspiron 1501 Notebook
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Sending a fax directly from computer using Canon Pixma MX 310
With the document open, you click Print, then choose Cannon ...Fax.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Jan 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX 310 - printer not detected message
Hi, I will assume that you are installing the Canon MX 310 to a Windows machine. Before going thru the install procedure, please check that you have USB enabled by right click on My Computer, Properties, Hardware, Device Manager, and at the very bottom USB Controllers should be there with no red or yellow markings. If they are not there, please restart your machine, press del or whatever it is to enter CMOS/BIOS setup and verify that the USB ports are enabled. In some instances, it may take some time before the PC recognizes the USB device such as your printer. You really have to give it time or one trick is to Cancel the printer port detection and just go ahead with the installation. When all is installed and finished, you can change the properties of the printer to USB port from the Parallel/LPT1 port. Another is to plug the printer straight in to the USB port (or try all the other USB ports) without installing it first. Allow/let Windows to autodetect and auto install. Put in the CD only when Windows does not know where the drivers/installers are located. Hope this be of some idea/help. Post back should you need further information. Good luck and kind regards.
Sep 09, 2007 | Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
