Question about Maytag Atlantis MDE8400AY Electric Portable Dryer
Dryer is too hot - Maytag Atlantis MDE8400AY Electric Portable Dryer
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
If you are having dryer problems and you cannot even get the thing to start, then you might want to start going through this check list of possibilities. There are a number of things that can cause your dryer to not run.
A couple of the most common problems are the thermal fuse has blown or the door switch is not operating properly. On many dryers if the thermal fuse blows, the dryer will not run at all. This fuse can be checked with an ohm meter. It should show continuity if it is okay. If there is no continuity then you need to replace it and also find out what else failed. This is a safety device that usually blows because something else allowed the dryer to get too hot. It is usually located in the back of the dryer, on the blower housing. Some are oval in shape and others are rectangular, usually with two wires attached.
A defective door switch or a bent door switch lever can also cause you to have problems. If the lever is broken or bent it will not activate the switch. If the switch is broken, this also will not allow the dryer to be started.
The push (or turn) to start switch can go bad, but is unlikely. To check this, hold it in or turn it and then check to make sure you have continuity with an ohm meter.
If the dryer starts and then stops when the switch is released check the control board or the ?even heat? control on some model dryers. Some dryers have a belt break switch that can fail or your belt may be way loose or broken.
Check for burn marks or burnt wires at the terminal block on your dryer, poor connections can cause all kinds of problems. Also poor connections can cause fires.
A bad power cord also falls into this same category.
Of course, always check that you have the proper voltage to the outlet that you are plugging into.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Posted on Jun 06, 2011
Kenmore electric dryer got really hot and stopped working?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 19, 2011 | GE DVL223EBWW Electric Dryer
Dryer gets very hot
heatman101
Sep 17, 2011 | Kenmore 72622 Gas Dryer
Dryer is getting too hot
heatman101
Aug 10, 2011 | Whirlpool WED5300S Electric Dryer
Dryer was running very hot and now there is no heat
heatman101
Aug 08, 2011 | Amana DLE330RAW Electric Dryer
When the dryer is running top of dryer where controls is hot to the touch
heatman101
Jul 29, 2011 | Hotpoint NVL333EY Electric Dryer
Dryer gets hot but shuts off
heatman101
Jul 15, 2011 | Estate EGD4300SQ Gas Dryer
Dryer is too hot when using lower temp cycles.
heatman101
Jun 28, 2011 | Samsung DV218AEW Electric Dryer
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
Dryer got extremley hot and now doesnt turn on
heatman101
May 13, 2011 | Kenmore 600 6965 Electric Dryer
Dryer runs hot, and clothes are really wrinkled
heatman101
May 07, 2011 | Frigidaire Electric Dryer
Open Questions:
Only the extended tumbler option works. I have similar Maytag dryer model MDE8400AZW.  On any of the dryer settings, the dryer does not work (I will pull the handle and hold, the "damp" indicator light turns on without starting the dryer). I know it's not the motor because when I turn on the switch for extended tumble and turn my knob to extended tumble, pull the handle, the dryer will begin rotating as if nothing is wrong. I know it's not the door problem, because when I use my finger to press the door close "button" the interior light turns off and the extended tumble still works even though none of the other settings work. One strange problem I had was the turn switch.  Periodically, I would turn the setting to any random setting, try to turn on.  Repeating this at times would start dryer.  At first, I would only had to do this one or twice before working.  Later, I had to do this more and more.  Now it's not responding at all. I don't think it's the fuse because when I tried pulling the plug on the fuse, the extended tumbler doesn't work either. My first instinct was to replace the knob (I have not done so yet), but why is the extended tumbler working (every time) and nothing else? My guesses are 1. Knob is problem after all,  2. something is preventing any cycle that requires heat (maybe a thermomitor problem) One last thing, I've taken out the thermomitor (originally thinking it was the fuse).  When I shake it gently, I hear rattling metal pieces.  I'm not sure if this is normal or if it's broken.  I believe it's the maytag part 33002742.
Jan 05, 2009 | Maytag Atlantis MDE8400AY Electric...
Maytag Atlantis MDE8400AY Electric Portable Dryer Logo
67 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
