Kenmore 70 series won't spin
Kenmore 70 series (video above) top-load direct drive washer will not run spin cycle, but moves in 1/4 inch increments combined with loud grinding-type noise. It washes fine, it drains fine, I tested the motor independently and it works fine. I tried testing the brake underneath and it seems to release when I turn it manually, so I don't think that's the problem either. Could it be the gear box? The clutch? Is there any way to test these independently? Any other suggestions? Any help is very much appreciated!!
  • 5 more comments
  • bradeja May 24, 2008
    the basket is empty, so weight isn't the issue. How do I test the motor shaft? What signs should I look for that would show it's faulty. It seemed to have no signs of wear, or anything as far as I could tell.
    is the motor shaft the rod that extends up to the agitator?
    based on your list, I've narrowed it down to the spin bearing, the clutch, or the shifter (transmission). Is there any way to test these independently, or to be more sure?
    Based on the noise, would you say the spin bearing is the problem?
    any advice on how to replace a spin bearing? Is this a decent job for a non-newbie, but non-professional?
    Is the spin bearing located beneath the inner basket? How do I get to it?
    110.20722990
    Thank you, thank you for all your help!!
    Genius:
  • 3,422 Answers
HI,
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Goodluck,
Please don't forget to rate the solution.
Posted on May 24, 2008
  • 7 more comments
  • Priya darshan May 24, 2008
    In my 4th point of the tittle "if it doesn't spin" i mentioned if your washer is a GE,this also implies to frigdare and kenmore.
    I am sorry for the late reply and yes it is the bearing since it is making a grinding noise in the video and its time to replace it.
    Hold the clutch cone and turn the fluid drive housing around
    it. It should turn freely. If so, the bearings are probably good, and the
    motor shaft is probably bent.
    You can ha a look at THIS LINK once..
    Replacing the bearings requires a professional job.But still if you want to try replacing it yourself then i would recommend to use a service manual for your model.
    If you need anymore help let me know..
    Hold on i'll let you know if there is any service manual available for this model.
    Can you give me the model no.
    Please CLICK HERE
    It will hep you to get to the bearings.Everything is explained step by step with the diagrams.
    Hey no problem at all...
    Thank you for using fixya
    Sergeant:
    Champion:
  • 230 Answers
May be there will be fault in the motor shaft ..............or it may happen due to heavy load try with normal load and also check the motor shaft
  • balachander megavarnam
    balachander megavarnam May 24, 2008
    if the motor shaft has problem then also this may occur so check that
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 washer, does not move from one cycle to another
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd also look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 26, 2009 | Kenmore Washing Machines
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
May 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top loading washer 70 series
Hi I have a kenmore that is moving when it spins....some water left when spin is completed. We recently moved the machine to clearn behind it and this issue started. movement is about an inch per cycle.....can you help? thankse ,pde 22422
Dec 10, 2007 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
