Question about Whirlpool Refrigerators
Bottom compartment not cooling - Whirlpool Refrigerators
  • 2,299 Answers
There are a couple of reasons why this could be happening. Either the defrost heater is not working properly and the air is not circulating properly. Or the circulation fan is not functioning. If the fan is running then duct is probably built up with ice.
Posted on Sep 28, 2010
Fridge is not cooling, fridge is working fine
Hello Dan, Is Your Fan in your freezer compartment on ? sometimes the evaporator coils will freeze up not letting the air cool the refrigerator
Dec 25, 2013 | General Electric GFSS6KKXSS Stainless...
The bottom compartment of the Aficionado wine cooler doesn't cool. Are there replacement parts available?
Check to see if there's some hazzle in the bottom compartment. Things that are may block the cool air in lower compartment will cause that. Also dirty, spilled liquid can cause that.
Check it out, clean it and it will cool again.
Good luck.
Jun 12, 2011 | Refrigerators
Icing of freezer compartment. compartment freezes and pushes doors open.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Refrigerator compartment is not cooling. No air
your air deflector isn't opening up between freezer and refrige to let cold air down
Nov 01, 2009 | Maytag MFD2560HES Bottom Freezer French...
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Haire hvt18dfbb cant find any documentation on the product free online so here it goes, basically 1. rear cover off 2. dust free 3. light, fans inside and out running 4. seals intact 5. upper...
If either the top or bottom compartment is not cooling, then the thermal couple (cooling module) behing the fan and heat sink is bad. It can be replaced with part number RF 4545-14 but they cost $70 each. One on the top and another on the bottom. You would need to solder a few wires. I think, this is not worth the cost, since the fridge cost about $150. Also if you don't get power than the circuit board in the back has burned-out. The replacement for this part is RF-5210-37 cost about $38. I replaced the the circuit board after the fridge wouldn't go on. Now the top compartment won't cool and I need a thermal couple. Total cost would have been $130 and I think it's not worth it. So since I fixed the power issue, I will use this fridge just for my reds in the bottom compartment for as long as it will last. I will remove the broken thermal couple, maybe I can put together my own.
Aug 15, 2008 | Refrigerators
Refrigerator
I assume this is a frost free, the best thing to do is empty it switch it of at the mains and let it defrost for two days with the doors open, switch it back on again and it should be fine
Dec 03, 2007 | Samsung RB1955VQ Bottom Freezer...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
