Question about Garden
The pull cord will not recoil back into the mower and won't start it how can i fix that so my mower will work again
    Scholar:
  • 150 Answers
You probably have spring problem. You will have to pull the starter shroud off. Eigther the spring is broke or there is debris or rust binding things, if your lucky its the latter, clean and lubricate.
Posted on Sep 28, 2010
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
How to replace starter rope
Read through this completely before doing any work.
1) remove the plastic cover on the engine. Usually a couple of phillips head screws.
2) remove recoil housing. It will either come off as just the round part on top the sheet metal shroud or the entire shroud may need to be removed. You will need a rachet set for this.
3) remove any remaining pull cord from recoil pulley. You can do this by pulling the cords knot from the inside of the recoil pulley.
4) rewind the recoil in the direction of starter rope pull. Place a screwdriver once you have 7-9 turns made. The screwdriver goes between the spokes of the recoil pulley and the spokes on the recoil shroud. Align the hole in the pulley with the hole in the cover where the cord comes out. Then drop in the screwdriver.
5) get a new length of cord. *(check the old one for overall length as a guage) after melting and pointing the end of the cord push it through the outer hole till it shows at the inner hole.
6) tie a knot in the pulley end of the cord so it can be pulled back out and then remove the screwdriver while pulling tension on the recoil cord so it doesnt get totally sucked into the recoil. You should end up with about two feet of free cable dangling so you can put on the t handle and place it through the eyelet on the mower handles right side *(from operators position).
7) put the recoil cover back on the mower and try a slow pull to see if the cord has enough travel. If it doesnt, you will need to put more winds on it. Which might require more cord as well. You may want to go online and lookup your mower to see if you can find specs on how long the cord should be.
You should wear cut resistant gloves and eye protection at the very least while doing this procedure. Good luck and be careful!
Dec 04, 2011 | Toro Power Lawn Mower
We broke the pull cord and after pulling the cord won't recoil to proper position.
remove the cord assembly ,, either the cord is off track and needs to be rewound or it broke and needs replacement
Jul 16, 2011 | Toro Super Recycler Super Bagger Lawn...
My recoil starter will not pull back the recoil cord. the mower will start and run, but the cord will not go back into the recoil housing.
Go to smalleng.com they have free how to videos for just your problem, check it out it's a pretty cool website.
Nov 24, 2009 | Garden
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Garden Logo
185 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
