Question about Disney DTD1363-CAR 13" TV/DVD
No Power Tried reset, still no poer. Can't figure out how to remove wheels to op[en cabinet? Parts diagram or how to open the case would help. Schematic would be nice as well.
Don't know about your power problem, maybe you could be more specific. But, as for opening the case. Try this: Use a small flat screwdriver to pry outwards, on the nuts on the inside of the wheels, using the center piece as a leverage point. careful, it takes very little pressure to knock them loose. Behind three of the five nuts are holding screws. this will allow you to get at the fenders and remaining case screws. Note you will also have to remove 2 small screws in the back between the (RYW) AV connectors before splitting the case. Good luck.
Posted on May 25, 2008
"OP" what is the meaning of this code refrigerator frigidaire
Good Morning friend, thank you for your post!
I see that your Frigidaire refrigerator is displaying an "OP" error code and you want to know what it means. An "OP" could stand for open thermistor. This could be a possible problem with your thermistor or control panel. In any case that it is a false error code I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for roughly ten minutes. If that does not help resolve your issue I would suggest consulting with a professional technician for proper diagnosis. Hopefully this is helpful information. -Matt
Feb 12, 2015 | Frigidaire Refrigerators
How do I reset the disposal?
The question is too broad, but I will try to help. Assuming this is a kitchen garbage disposal, the unit is designed to shut off if the cutting wheel gets jammed.
1. Turn off the wall or cabinet power switch.
2. Remove any objects inside the disposal opening and ensure the cutting wheel moves freely.
3. Locate a square button on the bottom of the disposal and press.
4. Run water into the disposal and turn on the wall/cabinet power switch.
Oct 27, 2014 | Electrical Supplies
Hoe wiellagers achterwiel vervangen
Hallo , Mathkrist voor dit scenario knt u uw dienst / eigenaren manual nodig hebt als je de eerste en de beste tool die je ooit gekocht voor uw Yamaha , wanhoop niet kan niet vinden , voor een luttele $ 0 knt u een ander downloaden. Voor meer informatie over uw probleem en waardevol "FREE" downloads die je nodig hebt , klik dan op de onderstaande links . Veel succes en een mooie dag verder . Yamaha Star 650 Rear Wheel Removal
http://www.xj4ever.com/wheel%20bearing%20replacement.pdf
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Apr 12, 2013 | 1985 Yamaha XJ 700 X Maxim
How do i install a motor on a blanco dishwasher bfdwc65
Hi.
The parts' arrangement is similar to several Whirlpool model. The pump motor is located under the bottom place and it is accessed removing the front kick panel (in front at the bottom).
Here a movie showing the procedure on a Whirlpool similar to your Blanco. I also tried to describe the procedure below. Check also the parts diagram for your model at the end of this comment. Sometimes it is not necessary to lean the appliance on one side, depending on how you can reach pump motor and hoses. See movie and description.
To remove the old motor you need to:
  1. Disconnect power.
  2. Move appliance forward.
  3. Disconnect drain and inlet hoses and remove water from tub (if any).
  4. Remove baskets or anything else from inside the machine.
  5. Remove spray arms and remove the assembly at the bottom of the machine.
  6. Put some clothes or towels on floor and lean the machine on one side.Water will leak out, the clothes will help here.
  7. Take the kick panel in front off.
  8. Undo the screws that hold the pump to the machine cabinet.
  9. Use a flat screwdriver to loose the clip holding the hoses. Loose the clip but do not open it completely (it will help later).
  10. Pull off the two hoses.
  11. Disconnect the electrical connector to the pump
  12. Lift the pump motor and pull it out from cabinet.
To put in new pump.
  1. Insert the two hoses on new pump.
  2. Set the clips.
  3. Put the pump motor in place inside the cabinet.
  4. Arrange hose and pump motor correctly and put screws back.
  5. Reconnect the wiring connector.
  6. Lift up the appliance.
  7. Put back spray arms and internal assembly.
Before putting on the front panel:
  1. Connect power and test for leaks.
  2. Disconnect power and fix any leak present (adjust hoses).
  3. If there is no leak put panel back.
  4. Set back the appliance and connect power.
Always observe strictly health and safety prescription. Disconnect power before performing any maintenance. Beware of panel's sharp edges, particularly when removing kick panel and accessing parts in the tight space under the bottom of the tub.
Here diagrams showing all parts:Exploded view.
Regards.
Ginko
Sep 07, 2011 | Dishwashers
My son tried to adjust the brightness on our lcd monitor, and now it goes black one or two seconds after you poer it on... how can we reset it...
The Inverter may be bad. This is the part that applies high voltage to illuminate the backlight for the LCD's CCFL. It momentarily lights up on your display because a capacitor cannot sustain the charge to keep the high voltage constant - thus you see it come on when you apply power and then go out.
Oct 30, 2010 | Dell E153FPc 15" TFT LCD Flat Panel...
ZZR 600 bj 1991 HIJ vonkt WEL mare start niet Signature Mij Staat sterven niet op Tijd en IK vind De Vonk niet Echt Krachtig Nieuwe Bougies Nieuwe Kabels bobines zijn gelijk AAN Elkaar en de omse...
Hallo, P_kok en de gebruikelijke verdachten zijn:
1. Brandstoftank leeg.
2. De brandstoftank heeft oud dode gas.
3. Brandstoftankbodem vervuild met ethanolslib, vuil, water, roest, enz.
4. Brandstoftoevoerklep / petcock uitgeschakeld.
5. Verontreinigde bougies.
6. Motor overspoeld als gevolg van overmatig gebruik van de choke.
7. Vacu?mslang aan de brandstoftoevoerklep / petcock ontkoppeld, gebroken, gebarsten of geknipt.
8. Brandstofklep / petcock of filter verstopt.
9. Brandstofleiding naar carburateur of gaslichaam ingeklemd, geknikt of geblokkeerd.
10. Carburateur drijft vast.
11. Brandstofinjectoren verstopt.
12. Brandstofinjectoren steken open.
13. Ernstig ontladen of beschadigde batterij moet 12,5 volt of meer hebben en in voorkomend geval een correcte "LOAD" -toets kunnen doorgeven, u kan een cursieve lezing van 12,5 volt of meer hebben, maar weinig of geen stroomvermindering is de batterij defect en moet vervangen, AGM batterijen falen in dit scenario meer dan lood-zuur batterijen.
14. Controleer de batterijterminals voor beschadiging of corrosie. Controleer de batterijkabels op "BOTH" uiteinden voor losse, corrodeerde of gebroken connectors, "INSIDE" en buiten de kabelhaken, voer de connector wiggle test en controleer de kabels met een ohmmeter indien nodig.
15. Losse of gecorrodeerde draadaansluiting bij de spoel of de stekker tussen de ontstekingssensor en de ECM-module.
16. Stekkerkabels in slechte conditie en korting controleren op vonklekkage in het donker, kabelverbindingen los of aangesloten op de verkeerde cilinders.
17. Ontstekingstijd niet correct door een defecte ontstekingsspoel, ontstekingsmodule of MAP, CMP, CKP, O2, TPS, ETP, IAC sensoren.
18. Foutieve neutrale, koppeling, kickstand veiligheidsschakelaar. 19. Foutieve brandstofpomp of zekering of relais.
20. Een vast gebogen of verbrande klep.
21. Tilt sensor heeft een reset nodig.
22. Beveiligingssysteem dat alarm niet uitschakelt, heeft een reset nodig.
23. Controleer de motorcodes van de motor.
Voor meer informatie over uw probleem en waardevolle "GRATIS" downloads die u nodig heeft voor het bekijken of afdrukken, klikt u op de onderstaande blauwe links. Veel geluk en een geweldige dag. ZZR600 starting problems Horizons Unlimited The HUBB
ZZR600 ZX600 1991 infrequent or weak spark during startup
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Oct 16, 2017 | 1991 kawasaki ZZR 600
No heat
Could be that the breaker open on the heating elements. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Look at post on "no heat" in this forum will work you through your problem
May 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My creative megaworks thx 550 does not power on anymore
ok, so far, you said you checked the power cables and switch and they seem ok. But i have run into a simliar problems with some equipment i use. Sometimes a plug may go out of a strip, but not take out the entire strip( have that problem with a power strip right now actually, in the process of fixing that)
Also, im not sure what kind of Cabinet you have, so i dont know what to really suggest other than to find either the model of your cabinet and pull up the building spec's on it, if it comes with its own cabinet or contact the manufacturer.
Without having either a picture or name and product number. I dont feel i can really help otherwise with the problem.
Please be more detailed. I would be glad to help all i can, but more details will be required
Oct 28, 2008 | Creative Labs MegaWorks THX 550 Computer...
Roper Dryer REX4625EWO
You will have to remove the cabinet and fix the switch. Go to www.repairparts.com and enter you model number. They will have a diagram on how to remove the cabinet.
Dec 08, 2007 | Dryers
Cabinet removal
Follow these steps: 1. Open dispenser on top and remove screws. 2. Remove the door and screws opposite the door around the door opening. Front panel should come off. I'm trying to remember if the motor control board is in the cabinet, or under the console. Some washing machines now have the control board under the console. Just in case you open up the front casing and don't find what you're looking for, you can also remove the screws from the back of the console and it should lift up. Let me know if this helps you.
Jul 31, 2007 | Maytag Neptune MAH5500B Front Load Washer
Disney DTD1363-CAR 13" TV/DVD Logo
83 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
