Question about Linksys WRT54G2 Wireless Router
I lost my password for my WRT54G2 Linksys router. I need it to connect my other computer to the enternet.
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1? in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
Posted on Sep 28, 2010
Pppoe password on wrt54g2
You can contact your Internet service provider for your PPPoE password.
The PPPoE password is generated and given by Internet service provider only. If you are using PPPoE connection then your Internet service provider should have password. Or they can reset and give you a new one.
Jan 01, 2012 | Linksys WRT54G2 Wireless Router
I cannot access my WEP Hex Key, how can I locate it or reset it?
Connect to the router with an ethernet cable. Use a web browser and connect to 192.168.1.1 You should see a router home page. login as admin (default id= none/blank/null password=admin) These detailed instructions may help here http://nabtron.com/forgot-linksys-wrt54gr-password-how-to-reset-settings-of-the-router/180/ browse to the wireless/wireless security section and set up your WEP key. You can preview the web page layout here; http://ui.linksys.com/files/WRT54G2/ e.g. http://ui.linksys.com/files/WRT54G2/1.0.00/WSecurity.htm for you this would be http://192.168.1.1/WSecurity.htm
Jan 08, 2011 | Linksys WRT54G2 Wireless Router
Wont allow me to connect 2 additional computers and need pin name or number
Two methods to solve your problem:
Method 1:
(1) Using your currently connected and working computers, access the wireless router security page at 192.168.1.1 (page 8 of 44 from the WRT54G2 manual), default password "admin" (page 7 of 44 from the WRT54G2 manual)
PDF file of the Linksys/Cisco Wireless-G Broadband Router User Guide:
http://belkashop.com.ua/products_files/WRT54G2_V10_EN.pdf
You'll need Adobe Acrobat Reader to view/print this file - free from www.adobe.com
(2) get the WEP or WPA password, and enter it into the wireless LAN (WLAN) settings on your 2 additional computers.
Method 2:
Alternatively, access the WEP or WPA key on one of your working PC, by
(1) make sure the printer is working, powered up and online.
(2) invoke "Network Setup Wizard"
(3) wind thru various steps (click-ing NEXT), then select "Print Network Settings"
(4) use the printed WEP or WPA key in the WLAN settings on your additional 2 PCs.
Jan 02, 2011 | Linksys WRT54G2 Wireless Router
I lost my password
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Aug 13, 2010 | Linksys WRT54G2 Wireless Router
WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Jul 08, 2010 | Linksys WRT54G2 Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
L have lost internet connection with linksys wrt54g2 v1 router. l am getting error 323
Stop using the setup disk. It does not work. Connect to your router via a web browser to 192.168.1.1. Username blank, input your password and configure the router as normal.
Jun 07, 2009 | Linksys WRT54G2 Wireless Router
I lost my linksys wrt54g2 v1 cd i need to install the program because i need to connect to the internet from my laptop.
http://www-ph.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=PH%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740141396B01
Mar 17, 2009 | Linksys WRT54G2 Wireless Router
Setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54G2 Wireless Router Logo
163 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
