I need to print addresses on envelopes using the C350 Bizhub printer in the office. What I am looking for is an understandable step by step list of how to do it for someone familiar with this printer. For example, if envelopes cannot be processed from a specific drawer, the person needs to know that and warn me about it. I am also not looking for a cut and paste solution from the C350 users manual because the content is not very user friendly.
    President:
  • 2,777 Answers
Has anyone so far attempted to help you? I have done this process many times, and am sure I can walk you through it. It's pretty simple really, just a matter of loading the envelopes into the correct spot on the loading tray, and printing from there... it will automatically grab the envelope instead of regular paper.
Let me know how far you have got, and I will let you know exactly what you need to do.
Thanks
Tim
Posted on Sep 28, 2010
C350 driver
To offical konicaminolta website drivers are free.
Apr 10, 2014 | Minolta C350 Printer
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Apr 18, 2012 | Minolta bizhub 200 All-In-One Printer
How do i address envelopes on my lenovo Windows 7 computer
The simplest method of addressing envelopes is to use a word processing application such as Microsoft Word.
If you do not have Word then I would recommend downloading and installing a copy of Kingsoft Office Suite Free 2012 which is compatible with the latest versions of Microsoft Office documents and is free for home users.
Once the application is installed, open Kingsoft Writer 2012 (which is very similar to Microsoft Word).
Click on File then on Page Setup and select the Paper page tab where you can then choose the Paper size to use for your envelopes.
In the Paper size drop down selection listing, choose an envelope size such as C6 Env.
If you are unsure which option to choose, then simply measure the size of the envelopes you are wanting to print on and set the Width and Height values (in centimetres) to match that size.
Next switch back to the Margins page and select the Orientation that you want to use for your envelopes, i.e. Landscape or Portrait.
On this same page you can also increase the Margins to position your address text more centrally on the envelope.
Click on OK to exit Page Setup.
Type your address on the main Kingsoft Writer page and you are ready to print the envelope on your printer.
Kingsoft Writer can also use Mail Merge to write a series of addresses on a stack of envelopes if you need to write a number of addresses.
Simply create a list of your addresses in the Kingsoft Spreadsheets application, putting each 'address field' in a separate 'box' in the new spreadsheet so that you have a column each of 'Names', 'Address line 1', Address line 2, Town, County, Post code etc.
Then in Writer, click on Tools, Mail Merge toolbar, then in the toolbar, click on the left icon to Select Data Source and select your addresses spreadsheet document.
Next, click on the icon for Insert Merge Field and select all the address fields to insert into your new Envelope document.
Finally, adjust the layout of the fields by moving fields on to new lines as needed. You can also change the font and character size of the new address fields to make the text larger or bolder etc.
Last of all, click on the icon for View Merged Data which will show you what your addresses will look like when printed on the envelopes - you can step through the list of addresses using the controls in the toolbar.
Dec 23, 2011 | Lenovo Computers & Internet
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Hp officejet 6310xi doesn't want to print envelopes. prints everything else fine
Step One: Correct way of Feeding Envelop in Officejet.
You can refer to this webpage mentioned below for better understanding for the steps:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=buu03053
Step Two: Print the Envelop
  1. Right click on Printer icon and select Printer Properties.
  2. Now, Click on Printer Preferences
  3. Go to the "features Tab".
  4. Select Plain paper
  5. Select "Landscape"
  6. Under sizing options select "More". this brings up more options select envelope #10
  7. Put dot in "Scale to paper size"
  8. On next line click the down sign and select envelope #10 again from options.
  9. Click OK.
  10. Now, try to print using these settings.
Step Three: Change the Settings.
You can refer to this webpage mentioned below for better understanding for the steps. The steps are same for windows 7 and windows Vista operating system.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01518768
Note: Clicking the link may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the address box.
Step Four: Setting up the envelope size in Microsoft Word (Windows)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01913438
Feb 02, 2010 | HP Officejet 6310 All-In-One InkJet...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How do you print envelops - the names are never centered and theirs a ig space between name and address on envelops hp office jet pro 6480 all in one
Since there are few step you have to complete before you can pirnt envelop
and theis site will not let me listed all of the step and pic to show you how it is setup.
the following link is the HP 6480 printer define how the evelop printing is done.
start on page 21.
http://h10032.www1.hp.com/ctg/Manual/c01325559.pdf
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Bizhub C350 - Print spooler not running after power outage
I would print out a copy of the network configuation of that printer and ensure it has the proper network settings (I.E. IP address, Subnet mask and Default Gateway. I just worked on a printer that I accidently pull the plug on and it lost it's network settings and wouldn't print until I changed them back to the correct settings.
Good luck
Nov 11, 2008 | Minolta C350 Printer
Printer will not print ' Print Error'
Can you ping the printer?
If not, then check settings or for conflicting IP address.
May 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
71 people viewed this question
k24674
