Question about Dell Dimension 8400 PC Desktop
Start button on computer flashes yellow & computer does not start. Happens on & off. When using computer all power can click off & power button goes from green to flashing yellow..
    Scholar:
  • 56 Answers
I would suspect (almost always) a bad power supply. You should be easily able to find a new one for under $25, just make sure that it has the same types of connectors as your original (extra connectors are OK). If it's not the power supply, the motherboard (main circuit board) is almost certainly shot.
Posted on Sep 28, 2010
Dell 620s flashing yellow start button
Generally this means that it can't find the system disk. Most of the time if you press and hold down the power button, the computer will shut down. After that, restart and see what happens.
Jan 27, 2013 | Dell Inspiron 620 ST Desktop Computer...
I try start up my apire 6920g but it light up shortly every time i touch the button, but nothing happens except the quick flash...i guess its something with the power??
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 17, 2010 | Acer Computers & Internet
Power button if flashing orange and nothing else works
It's likely that your power supply has started to go out. There are several different leads with varying voltages & amps. If your computer is getting enough power to make a light flash yellow or orange then this often means that there is something wrong with one or more of the voltages from the power supply. Sometimes it means that something is wrong with your motherboard. Like: burned out capacitors, resistors, & etc.
Jul 06, 2010 | Dell Dimension E310 PC Desktop
I was playing music off PS3 HDD when we had a power cut for approx 0.5sec. Surge/spike protecter was fitted to power source, but no power back up was fitted. Error msg was on screen saying to turn off PS3...
This is a processor error. There is no way to get to the restore screen when you have the yellow light issue. Try CPR in NYC. They usually have a 1-3 day turnaround time, and are pretty cost effective. You can easily ship them your unit. They are faster and cheaper than Sony!
website is www.cpr-nyc.com
Hope it helps!
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
I have a Toshiba Satellite SA40-271 model. When you want to start by pressing the START power LED yellow flashing on and does not start.
To change your computer power saving plan, automatic shutdown, or to check power settings, go to, (Control Panel), click on Change Power Settings. From here, choose when the Computer Sleep, when not in use, how long the display stay on, and when the computer should shutdown etc. I hope this Fix it.
Jan 17, 2010 | Computers & Internet
Software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
Dec 28, 2009 | Panasonic SDR-H80 Hard Drive Camcorder
I have a canon mp830 that is has trouble code 5c00 on the lcd. the power light and trouble light flash alternately green and yellow respectively. I've cleaned the print head. How can I reset the printer to...
Canon MP170, MP450, MP530, MP600, MP610, MP800, MP810, MP820, MP830, MP960, MP970
MX700, MX7600, MX850
1. Switch off the printer the button Power
2. Holding button Resume (the red triangle in ring), include the printer (press the button Power ) - an indicator fires green cvetom.
3. Holding button Power , release the button Resume
4. Not releasing button Power , two times press the button Resume and release both button.
5. After indicator of the cut-in/readiness flashing.. and fires constantly, fall into service mode.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-yellow.
7. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
Jul 09, 2009 | Canon Office Equipment & Supplies
How to shut down dell inspiron 530 computer - the button only takes computer to sleep mode
I assume you use Windows Vista.....
In vista the default action of the power button is configured to sleep mode..
So to shutdown the PC you can press "Start - right arrow - right arrow - right arrow - Enter", or you can navigate to the same using the mouse & selecting shutdown from the list besides the lock icon.
You can also change the power button configuration this way goto " Start-Control Panel-System and Maintenance-Power options-change plan settings (under the current plan you are using) - change advanced power settings - Power buttons and lid - Start menu power button" click on settings and select shutdown, apply & save the settings and close this window.
Now you can just click the power button to shutdown your computer.
Jul 05, 2009 | Dell Inspiron 530 Desktop Computer
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 8400 PC Desktop Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
