Question about RCA P52960 52" Rear Projection Television
What does po vo 122 means on my tv screen whn this happen the remote does works and you can't turn the tv on or off the buttons seems to be out of line?
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: how can i get my rca to work
open the remote control and clean the keypad with special spray contacts cleaner from dirty, oxide, etc.Resolder the colder joint for a good contacts.
God bless you
Posted on Jul 01, 2012
Polytron tv service center
samsung led tv remote reset pinhole button
Jun 22, 2013 | Televison & Video
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
How can i get my rca to work
God bless you
Jun 30, 2012 | RCA Televison & Video
Remote will not do anything
1) change the batteries by new ones
2) clean the contacts batteries with spray contacts cleaner
3) resolder the wires connector batteries.
4) open the rem.contro and clean the keypad from oxide, with cleaner contacts.
5) otherwise you must go to the repair shop TV.
God bless you
Jun 30, 2012 | Televison & Video
Remote does not work,need code for Sharp tv
Hello
Three digit universal remote codes for Sharp TV are:
004, 006, 012, 026, 029, 095, 111, 112, 113, 122, 171, 173, 196
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes are:
1004, 1006, 1010, 1012, 1013, 1040, 1061, 1089, 1092, 1093, 1111
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Genteral proceedings to enter code is as follows. It may differ to different remote controls.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Sep 22, 2011 | RCA ACC-RCAURC Remote Control
Child lock
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
Feb 15, 2008 | Akai CTS2550 25" TV
My mptv68a tv locked (don't know if it's child lock)
Try these codes to unlock the TV
0711 or 0000
Feb 01, 2008 | Televison & Video
RCA 52" Mdl P52939, PTK195S16B
but there are two
quick things you might be able to do. If it is a PTK195 you can most
likely install the updated power supply board. If you can solder and
know safety (like discharging caps) you can update the PS chip from an
STK730-??? to an STK730-180 (IIRC). I found that simply replacing the
chip with an equivalent fails most of the time. The 180s seem to hold
up.
Aug 11, 2007 | RCA P52939 52" Rear Projection Television
Tv is locked
I had the exact problem...tried a number of things that did not work. My dog "ate" my original remote. After reading your solution I took the universal remote that was programmed to work with the tv and tried holding down each button for a few seconds hoping that one would work like the display button on the original remote. It worked. I have a GE universal remote and the menu/info button worked for me. Again, you need to hold it in for a couple of seconds. Thanks for the help and I hope my added solution helps other people. Claudia in Minnesota
Feb 15, 2007 | Haier HTF20R21 20" TV
RCA P52960 52" Rear Projection Television Logo
90 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
