Question about GE Washing Machines
Water will not drain. Lid Switch works, agitator works, timer working. In rinse/spin there is a humming sound but nothing happens and then the timer advances. what's the solution?
  • GE Master
  • 3,051 Answers
Hello there:
This is normally due to a clogged drain pump
take the bottom front panel off and removed the drain plug/trap. then clean all that out and now the washer should work fine Now on me of these machines
The drain plug is on the front of this washer - you can see it without removing anything - there is a small 5"x3" panel on the front bottom that you pull out and then the plug twists free - have a large pan ready and unsrew slowly - water will come gushing out - have towels at the ready!
There are 2 screws on the bottom of the larger bottom front panel - remove these and you can see inside
you will see the drain plug housing is connected to the water pump and there are two hoses connected to the housing and the pump one coming from the washer to the drain plug and one going from the pump to your drain.
Remove the hoses carefully - using pliers to pinch the clamps together.
the hardest part of this is removing the drain plug housing and pump - because it seems like you should be able to just remove the pump - but you can not!!
There are two screws holding in the housing and pump - remove them and the whole thing pulls clear.
Once out you can make sure there is not more coins or **** in the thing. Three screws hold the housing to the pump - mark these with a sharpie before you remove them - because once it is off there are multiple ways to re attach it.
Once free of the drain plug housing spin the pump a few times and put it all back together -
Hope this is very helpful for you
Best regards Michael
Posted on Sep 28, 2010
  • kaesmith86 Oct 08, 2010
    Thank you so much! You saved me from having to buy a new washer! I washed a pillow in my washer and somehow it came apart and the stuffing was everywhere, then my washer wouldn't drain. I was about to throw it out until I read this, thanks again for your expertice!
  • mr_repair151 Oct 19, 2010
    I agree I bought a timer and still had same problem , took the pump and hoses off and they were clogged with sand (grand kids were here for the weekend ) cleaned everything and it runs like new . THANK YOU VERY MUCH !
Kenmore model 11020842990 series 80. had a severely unbalanced load in the rinse cycle. opened lid, rearranged clothes, would not start up again. Removed clothes to dryer, luckily most of water had...
when it went unbalanced the tub most likely broke the lid switch part
3949238.open the lid,on the right side of lid you'll see a strike,it goes into a hole and this is where the lid switch is,stick a screw driver into the hole,if you don't hear a clicking sound the switch is broke
http://www.youtube.com/watch?v=MFsvLiuTniU
Oct 15, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore 300 model 110.28322700 won't run. motor makes humming sound
Pre Thanks for help.
I have read all above and these are my symptoms.
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
however i tested my lid switch with a multimeter and the lid switch seems to be fine.
What else could be my issue?
Kenmore 300 110.28322700
Dec 03, 2011 | Washing Machines
Washer skips spin cycle what is the most likely problem
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the lid switch assembly, you jump it to test it. If the lid switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Kenmore Washing Machines
RCA Whirlpool Model LSQ9665J will fill with water but does not agitate, spin, or drain on any cycle. Was working fine yesterday.
put the timer on spin,open the lid,with a screw driver push down on the lid switch,if the washer starts to spin and drain the lid switch is bad,also if nothing happens,lift up and push down on the switch if you don't hear a clicking sound the switch is bad,all it is is a safety so the washer won't run with the lid open.part number 3949247 and the lid switch is around 40 dollars,
Apr 02, 2011 | Whirlpool Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Will agitate; but won't go into rinse or spin - even if place the
If it will not spin/drain/advance timer or make any noise when you set it to do these options your problem is the lid switch. Your washer thinks the lid is up so it wont run as a saftey measure. You can order and install this item and its pretty easy and very common.
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
Washing Machines Logo
248 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
