Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Where can I find recall or product failure information for the wiring harnesses on John Deere Tractors and Combines?
    President:
  • 1,627 Answers
If you can give me the serial number i can run it to see if there are anyP.I.P'S need to be done,also if you can tell me what it is not doing that it is supposed to be doing i may be able to help.Keep in touch,i work on Deere combines frequently and i should be able to help you.
Posted on Sep 29, 2010
Where dose hot wire go to from coils on la145 22hp v twin
the coil wire is only a kill wire. it goes through the wiring harness through safety switches back to the ignition switch.
Nov 10, 2016 | John Deere Garden
Why will a john deere 1177 combine not raise or lower the table
Check fuses first. Rocker switch. Look at wire harness to see if rats have chewed on it. That is a problem in my part of the country. Clean all connections on wire harness. Be sure pin connectors are not burnt and bad connection.
Sep 10, 2016 | John Deere Garden
John Deere LA140 wiring diagram
Request the wiring diagram directly from John Deere.
Jul 28, 2016 | John Deere Garden
Where can i find a John Deere la115 wiring harness diagram?
The John Deere site has the wiring harness diagram on the LA115 parts diagram in the Electrical section (section 40, page 19). Start here: https://www.deere.com/en_US/parts/parts.page and select the Parts Catalog. http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt is where I ended up. The carburetor is in section 30 (Fuel and Air), page 10.
I hope this helps.
Aug 03, 2015 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
John deere wiring schematic
you have to go to John Deere for this...
Aug 28, 2014 | John Deere Garden
John deere x320 will not syart. if one coil ground is disconnected it will start right up. if started this wsy the pto will not engaage.
The wiring harness under the engine shroud that feeds both coils has a diode on each of the wires that connects coils.The diodes keep each coil from grounding each other out so when one diode goes bad it will only run on the cylinder with the strongest coil.Order new harness from Deere,cost less than $30.
Jul 02, 2009 | John Deere 3010,3020 Tractor Basic...
My fuse keeps blowing on my neutral safty switch on my John Deere 10c backhoe. What would you recomend to fix it?
Hello williamhowar:
>>As I am Sure you are Aware, Most Backhoes do a Lot of Bouncing and Jarring. LOL.
>>If you can Trace the Harness, then Check of a Bare Wire that is May be Touching the Unit.
>>If the Harness is Good, then I will Require some More Information about this Unit in Order to Assist you Further.
>>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
Thanks.
Respectfully
jbridger (John)
Apr 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
161 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
