Question about Boating
Have a evinrude 60 hp 1972 model when throttleing up runs fine for a few mins then it seems to start cutting out like if its run out of fuel
    Top Expert:
  • 45,291 Answers
Quite possibly is the carb floats might not be set properly .
Posted on Nov 02, 2010
2003 2 stroke evinrude 225 hp outboard will run at high speed about 5-7 min than starts shaking seems like not all cylinders are firing. if i shut off the motor and restart it will run another 5 min.
check the plugs if they wet its getting too much oil in the mix. if dry and black plugs then it could be not enough oil or fuel in mix.
Jun 21, 2017 | Cars & Trucks
I have a 1988 30 hp.evinrude that starts and runs fine till i reach 3/4 throttle,then it will die.ant suggestions?
Fuel line could be sucking air.check breather not blocked on fuel tank.if fuel bulb sucks flat,means blockage btwn bulb and tank.have you tried priming motor while running at full throttle.could also be dirty carb
Jul 15, 2014 | Boating
1996 merc. xr6 cutting out
Could be throttle advance linkage, loose electrical connector, or ground.
Jun 07, 2013 | Boating
30 hp evinrude outboard, running full throttle, then surges as if running out of gas. Will conk out if not taken back to idle. Whats causing this?
Sounds like air is getting into the fuel line. If you have a squeeze bulb primer check to make sure that it stays firm after you run it a bit. I had an air leak on a clamp attaching the primer bulb to the fuel line and the same thing happened to me. When the engine starts to cut out squeeze the primer bulb and see if it starts running better, if it does then you probably do have an air leak in the line and it is losing it's prime. Hope this helps!
Feb 19, 2013 | Boating
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
Starts well,runs wellfor five mins but then cuts
My first guess would be the fuel filter. It is probably almost completely plugged.
Oct 23, 2009 | 1991 Volkswagen Passat
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Apr 25, 2009 | Garden
Boating Logo
128 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
