Question about KitchenAid KERC607 Electric Kitchen Range
Our KitchenAid Model KERC607 always has the symbol for temperature probe on the display, thinking the probe is plugged in, and pressing "Cancel" does nothing to remove the symbol. We don't even own a temperature probe. Any easy way to turn this off, other than unplugging the range?
    Sergeant:
  • 270 Answers
This obviously not an isolated problem.
Go here and see what they have to say...
http://www.applianceblog.com/mainforums/kitchenaid/12867-kitchenaide-issues-temp-probe.html
Here is good information about appliances. Why re-invent the wheel
Posted on Sep 29, 2010
My kitchenaid temperature probe won't turn off
If you mean the probe icon will not leave the display, you need to be sure the probe jack is not coated with food residue that is grounding it, if it is clean- send the control in for rebuild. Help Me Find My Model Number RepairClinic com
Feb 24, 2015 | KitchenAid Ovens
I bought a new home and there is no manuals and it is stuck on the setting sabb the stove top works perfect but the oven only heats to 260 on this particular setting??
Try this:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Hope it helps!
Jul 27, 2011 | KitchenAid KERC607 Electric Kitchen Range
How do i set the temp to farenhit
If the model number is correct, changing between Farenheit and Celsius is accomplished by following these steps:
1. Open oven door.
2. Press CANCEL/OFF.
3. Press number pads 1, 2 and 3 in that order.
4. Press BROIL, then START.
5. Press BAKE to confirm.
NOTE: Only the temperature and a flashing degree symbol will display when the oven is set for Celsius.
These instructions are listed in the Operator Controls section of your owner's manual on about page 11. If you no longer own a manual, you can obtain a FREE copy at managemylife.com. Just enter your model number under their "Manuals" drop down menu and your owner/operator manual should be listed in .pdf (Adobe) format.
Is this is not the correct range, or if you have additional questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Jul 14, 2010 | KitchenAid KESC307 Electric Kitchen Range
Probe indicator beeping. Can't turn off.
there is a continuous beep on my oven and it says enter the probe temperature. I never used and would like to cancel...how?
Oct 09, 2009 | KitchenAid KGST307 Gas Kitchen Range
Our figidaire electronic stove/oven model PLES399ECD, serial number NF62311528, mfg'd 2/2006 has an error code for F30 when any program is selected. The manual does not list F30, what is F30?
Open (F30) or shorted (F31) RTD sensor
probe/ wiring problem. Note: EOC may
initially display an "F10", thinking a
runaway condition exists.
1- Press Cancel key.
2- Check wiring in probe circuit for possible short or open
condition. Check RTD resistance at room temperature
(compare to probe resistance chart). If resistance does not
match the chart, replace the RTD sensor probe. Let the oven
cool down and restart the function.
3- If the problem persists replace the relay board.
Sep 25, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Temperature probe in Kitchenaid YKEMC308 stopped working
4455636 sensor, 4451442 thermostat 4450812 thermostat controller, could be all three, I usually start with the controller over 80% of the time thats it
Nov 30, 2008 | KitchenAid KERC500 Electric Kitchen Range
KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Dec 10, 2007 | KitchenAid KGRC608LSS Gas Kitchen Range
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KERC607 Electric Kitchen Range Logo
425 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
