Question about LG Heating & Cooling
I just had a flex multi split ductless system installed. when it comes to heating and cooling there seems to be about a 4 degree range between when the heating and cooling comes on and off. also,the thermostats will only read in two degree increments is this normal? Thank you,
    Habit-Forming:
  • 156 Answers
Read your maunual. It might be normal. A 4 degree split in your set back heateing control is about normal. It is that way so you can turn your unit on and never really need to touch it again. When the temp goes up, cooling goes on. When the temp goes down, heating comes on.
Posted on Sep 28, 2010
I am not able to get the unit to change from air conditioning to heat
Unfortunately these units are not user fixable , beyond checking for power and checking battery in remote. You would need to call a pro who is able to get service information and has special digital logic meters to diagnose and repair .
Oct 04, 2014 | Mitsubishi MXZ-2B20NA-1 Mr. Slim Dual Zone...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
I have 3 Fujitsu heat / cooling multi split ductless units connected to one rooftop unit. Only in heating mode and only coming from the same indoor unit is a loud almost screeching/vibration sound. It can...
If it happens in heat it must happen in cooling. The indoor unit has nothing to do with if it's heating or cooling. You likely have 2 moving parts in the machine, the blower wheel and the swing fins. Turn swing option off, eliminate that. You get the rest...
Jun 04, 2017 | GE Zoneline AZ38H12DAD Split System Air...
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
Hi, I have a Daikin Model FTXS35D with RXS 35D 3VNB outdoor unit. Until this year it was excellent, now does not cool as before. Have cleaned filters etc. Could it be a sensor problem. When I...
Your unit should cool 15 to 20 degrees. 75 return air temp should be below 60 degree supply air temp. If you are not in this range you likely have a refrigerant problem.
Aug 14, 2017 | Cfm Daikin R410a Split System Air...
Fujitsu 18000 goes into defrost once an hour at 28to 32 degrees outside temp. trying to maintain 70 degrees inside . test run was ok on start up. just installed 3 days ago .. vacuum out the lines. lost...
what is the lowest outside temp manufacturer suggests? Heat pumps are not very good when it gets good and cold... call the installers and see what they have to say for you.
Feb 21, 2010 | GE Quiet-Aire Ductless Heat Pump Split...
New install. 40 seconds on. 20 seconds off.
Its normal that the air coming out is warm cause you set it to heat mode. Check your setting temperature, it is normal for the unit to shutdown when it will attain the setting temperature and operate when the temperature is lower than the setting temperature(heat mode).
Mar 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
76 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
