Question about Mitutoyo 500 196 20 Digital Caliper
How do you use the origin button? - Mitutoyo 500 196 20 Digital Caliper
Reset to original settings
Hello, Factory Reset is done by turning the phone off, holding the volume up button, holding the home button and then holding the power button till the phone vibrates and you can let go of the buttons. Use volume up and down to move through options and power button to select (don't have to hold, just press once). Select "wipe data" and then "factory reset". Select "yes" to delete all user data and wait for format to complete. Then power off then on and it should be back to original settings. Hope this helps.
Oct 21, 2014 | Samsung Galaxy S III S3 SGH-T999 4G White...
How to change paper size in drower in toshiba e-studio166
press and hold original and copy button the light starts blinking on original side select the paper size by pressing original button and press start button once you selection is made.
Apr 23, 2014 | Toshiba E-Studio 161 Copier
Press and hold original and copy button the light starts blinking on original side select the paper size by pressing original button and press start button once you selection is made..
Apr 23, 2014 | Toshiba e-STUDIO166 Printer
I have a tk-7180 and a 16 button mic and i cant seem to get the buttons to work
What type of 16-button mic you have???...is it the proper one(original)???...or you want to replace the original???
Mar 09, 2014 | Kenwood Radio Communications
What if you don't have original remote? Can you access this from tv buttons
Most of the time you need the original Sony remote for key functions in this set--What exactly are you wanting to do--not explained here.
Apr 11, 2012 | Televison & Video
How do you turn on the closed captioning?
U must have the tv original rmote.U have the tv original remote wright?Yes,look at the tv remote carefully for a button that said CC this button sit between the MTS and the DISPLAY buttons second row of buttons near the bottom of the remote.Pushes the tv remote CC button a couples of times u will get like CC1,2,3 so on 1,2,3 so on will give Closed Captioning if the tv programming offer it.If u don't have the tv original remote.Try website like Remotes.com to buy the tv original remote.I have one of this tv too.
Sep 14, 2011 | TruTech PVS31170S1W 17 in. LCD Television
I have an older model sansui tv with out original remote. Somehow captions were turned on and I can't figure out how to turn them off. Help asap!
Ur tv have a button that said Menu on the bottom tv beside buttons only said POWER,CHANNELS + -,VOLUME + - ?Used the tv menu button go through the options functions look for Close Caption find CC 1,2,3 or TEXT 1,2,3 turn it all off,will stop captionning,if tv have no Menu option button.The captionning can be turn off by an original remote only.Try website like Remotes.com to buy the tv original remote.
Apr 27, 2011 | Televison & Video
No picture
U have the original remote.Push the button said input or video to get out back regular tv.Or push the button on the front of the bottom of the tv pannel said menu push that button pick tv. U don't try Website 1-800- Remotes Factory Original.To buy an original or compatible remote.
Feb 16, 2010 | Sanyo DS24205 24" TV
Nokia 6103 LCD screen broken, need to transfer contacts to SIM
Menu
down once
menu
menu
upper left
down 4 times
menu
menu
down once
menu
(now you have to decide - for keep original press menu, for move original down once and menu)
upper left
menu
Dec 11, 2008 | Nokia 6103 Cellular Phone
Mitutoyo 500 196 20 Digital Caliper Logo
190 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Glenn
Glenn
Dragan Manojlovic
Dragan Manojlovic
Level 1 Expert
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
