TV is plugged in wall. I turned it on this morning and it didn't do anything. We haven't had bad weather or any power outages. I have tried leaving it unplugged, plugging into another outlet, and unplugging from back of tv, but no luck. Could it be the power supply cord? This tv was a wedding gift and only used 1 and 1/2 years. The manufacture date is May 2008, model 32CV51OU, CHASSIS No. TAC0814, Serial No. AM407025781. If it is something simple, can I do it myself? I have some electrical knowledge, but limited. Thank you. Johanna
  • jlbfast Sep 29, 2010
    Thanks, this did help and I think it is the PSU. I will have to take it in, but at least I know what I am looking at in terms of repair. Thanks for the prompt attention.
  • 19,396 Answers
Hi Johanna.
If the TV is completely dead , then it is usually either power cord, power outlet or PSU. Other faults are quite unlikely to cause no power.
Start checking the fuse in the power plug if the power cord is fused (eg. in UK the power cord is fused). In that case the problem is likely the fuse.
Test the wall plug using a different appliance.
The rest will require technical training. The power cord is tested reading Ohms between each prong and its respective soldering joint on the PSU board.
The PSU is tested reading Ohms and volts in different points, there is also a diode in proximity of the AC joint that must be tested.
If the TV is completely dead and power cord is OK, then you can risk replacing PSU, but there is always a little chance that problem is other (digital board, even if very uncommonly can cause no power), lose connector etc).
If the TV is completely off, check also if there is a main switch at the back of the TV, some of this Toshiba have a main on off switch at the back or on one side.
If the TV is in standby, then things are much different. In that case the problem has been detected by the main controller board inside the TV, and TV has been forced to stand by. In that case the problem can be anything and TV must be tested thoroughly.
Check the power cord, if that is OK, then PSU will probably need replacement. Price of the part is $80, labor may vary. I suggest calling Your local Toshiba service number, the number is listed on the TV manual. Discuss with them the repair or ask their price for the replacement PSU. The TV is surely worth repairing, and cost is probably less than you are expecting.
Here replacement parts: 32CV510U.
Posted on Sep 28, 2010
Display panel went black this morning. no power outage, just went blank.model mfi2269vem3 and serial number k04579390 . can it be reset
THis could be several things. The wires that go to the door could be bad, opening and closing the door causes this. The power supply could be bad and the display itself could be bad. You can try unplugging the unit from the wall for 5 minutes and then plug it back in. That is the only reset on it.
Jan 28, 2017 | Refrigerators
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
We are have power outage and we can't get our 50"
Have you tried unplugging the TV from the wall for 5 minutes?
Also have you tried plugging something else into the outlet to verify that the outlet works?
Aug 23, 2013 | Televison & Video
I have a Samsung 1080 (I think) that was purchased in December. Due to bad weather today, my daughter plugged while it was still on (didn't turn off first, just unplugged the tv.) Now it won't...
The processor could be locked up on it, or the power supply needs replaced, or electrlytic caps need change out on the power supply. That TV goes to off mode when it is pulg in, I don't think that there was any damage by pulging it in. Leave it unplug for 40Min., and that will reset the processor back to normal.
Jul 14, 2011 | Televison & Video
We had a power outage today and our tv won't turn on - there is a green flashing light on the front panel and that is it.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 18, 2010 | Televison & Video
Power outage this am. Wii won't even turn on
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
The electricity went off this morning...Now the Wii console power won't turn on....
Confirm the wii is plugged in (wall and wii side); if the wii is plugged into a power strip, confirm the power strip is plugged in, and that any on/off or fuse switch on the strip is set to on (may have been tripped during power surge/outage); unplug the wii for 15 minutes (seriously, 15 minutes), then plug it back in and try again.
TV won't turn on
Hi There,
Try unplugging the TV and wait 5 minutes, plug it back in. Let me know what happens.
Mar 29, 2009 | RCA Televison & Video
TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Jan 17, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Toshiba TV/DVD combo turns on then off again.
try letting it sit for 15-20 minutes unplugged from the wall and maybe try another outlet depending on if u got plugged in to a power strip, possibly pulling to much power from that perticular outlet.
Oct 16, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Electro Med Services...
