Question about Kitchen Ranges
Both sides are not getting cold. fan works its about 4 yr old unit. i checked the fan area , cleaned dust off of screen cage, etc. 1. cleaned dust off of cage 2. unpluged unit to allow to reset 3. checked inside for any restriction with fan 4. it sound like the unit cycles thru , will kick off just not getting cold
  • Kitchen Ranges Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 29, 2010
GE refrigerator GFE27GSDASS not cold enough, putting a fan behind the unit fixes this.
Check to see if the condenser fan is turning. Right next to the compressor
Jun 20, 2017 | GE Refrigerators
My 7-yr-old sony wega keeps restarting; blinks 30 times then video comes back on
Two things here to suggest: one is lamp life is 2000 hours or two years average--and many lamps that fail will either dim just a bit, take a bit longer than did to come up to full brightness and the set may detect that and try to blank the screen.
I am saying a lamp even if lamp light does not come on may be the problem or not.
Second, and I have seen this a lot, the fans in the set intake air in the front of the unit and exhaust it out the rear and no matter how clean the house is dust will get pulled inside.
Fans and air-path's can get coated with dust. Especially the blades on the fans, if a fan slows down just a little because of dust on its blades the set will also detect it as it monitors fan speeds etc.
A good dusting out with compressed air (try not to blow the dust into the screen area) will either confirm this or eliminate it as the problem. I almost always do it in the garage or outside as it may look like a dust storm when you do it.
These are my thoughts and I hope they may help you resolve your problem.
SD TECH
Dec 16, 2012 | Televison & Video
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Jul 09, 2012 | Danby Heating & Cooling
Wan,t get cold
4 simple things to check
# 1 Is the door gaskets sealing?
# 2 Have you cleaned ( blown ) the dust out from under the unit (coils ).
# 3 Is it defrosting? Too much ice in the freezer interferes with the cooling air flow.
# 4 Are both fans working? 1 fan in freezer and another one below the unit.
Dec 28, 2010 | Refrigerators
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Fan blower overheating
Sounds like your motor is bad check when it was installed all the units have a 5 yr warranty on parts but a HVAC contractor has to change it for the warranty
Dec 09, 2008 | Ruud Handler Air Conditioner
Ge refrigerator not cold enough
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 11, 2007 | LG LRSC21934 Side by Side Refrigerator
Sider webs
Here's my suggestion: I have a 55" Philips HDTV and I live in an area known for excessive dust and more than a fair share of spiders. I checked online and found that there are usually 1-4 access panels that can be removed for cleaning, repair, etc. Here are my steps: 1. Remove the upper most panel (usually a trapezoid-shaped plastic "box"). There are anywhere from 1-4 "hangers" that, once all the screws are removed, will hold the panel in place while you are unscrewing the last few screws. 2. Remove the panel and clean with a lint-free cloth the entire inside of the panel. This is an area where a lot of dust and spider webs can be found. 3. Grab your vacuum cleaner and carefully clean away all the spider webs. Making sure you don't bump into the inside of the projector screen! 4. Spray a small amount of dust cleaner or window cleaner on the lint-free cloth and run the entire length of the TV. Clean all surfaces this way except the reflector (mirror). It is best to clean the mirror with compressed air (get it anywhere - usually in the computer section). 5. Using a flashlight or bare lightbulb, thoroughly inspect all surfaces for dust and spiderwebs. And, of course, clean anything missed the first time around. 6. Using a clean lint-free cloth (I find cotton underwear from Wal-Mart works the best), spray a very small amount of window cleaner (streak-free Windex, etc.) on the cloth and rub the cloth together until almost dry. Then, simply wipe all three lenses clean. 7. Replace the back panel and pay close attention to the alignment of the holes to ensure the screw goes back in the same way it came (if not, the panel could ultimately lose the seal and allow for more dust). 8. Allow for several minutes drying time before turning the set back on. Hints: 1. Clean the speaker area, too. 2. Repeat the process at least each 30 - 45 days to ensure optimal performance. 3. Use a small computer fan to circulate air behind the set if the area gathers excessive dust. They're quiet and can be purchased (almost anywhere - Radio Shack, Wal-Mart, etc.)with switches that are easily accessible.
Sep 01, 2006 | GE 46GW947 46" Rear Projection Television
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
