Question about OKI MICROLINE 590 Matrix Printer
PRINT NOT DARK ENOUGH - OKI MICROLINE 590 Matrix Printer
Why are my pictures so dark?
Your ISO was to high or to low , I cant see your pictures to tell, but darkness means you diidnt let enough light in the lens set your appuatue to a small number and slow down your shutter speed. It will help preveiw your pictures before you print . Download Picasa for free and fix your pictures its easy. Goodluck Ozout!
Jul 28, 2014 | Nikon D5100 Digital Camera
My eltron ip2844 wont print dark enough. I went into setting and turned the burn darkness to 15, but still not dark? Help!!
This may be due to your thermal paper.
This printer doesn't deliver enough heat to your paper or you have a problem with the head pressure.
Press on the bloc while printing to see if it's this reason?
You may also have a mis-alignement of the thermal head.
Try also to change the print speed?
Aug 05, 2011 | Zebra Eltron LP 2543 Thermal Label Printer
Omni 3740 not printing dark enough
The print on our Omni 3740 is not working. We have to push the cover down hard to make it print. I think the roller is not pushing hard enough or the clamp to hold the cover is out of alighnment. Need help.
May 26, 2010 | Office Equipment & Supplies
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Typewriter is not printing dark enough. Is there
Many SCM typewriters have an impression control knob on them. Look for a knob on either the right or left side of the the keyboard with numbers from 1 to 10. The higher the number reading the darker it is supposed to print. Be careful not to go so high that the typeface cut holes in the paper. If this doesn't help, try putting a drop or two of sewing machine oil (or Triflow Oil) on your finger and rubbing it across the typebar segment (the slotted and curved metal piece that the typebars pivot in). Since the typewriter sat a while the segment may be sticky. Hope this helps.
Aug 25, 2009 | Smith Corona Office Equipment & Supplies
The black is not printing dark enough. It shows it
it is problem your printer black cartridge
you change it or
technicaly you drop your black cartridge in water withen two days after tow days you dry black cartridge and clean head printer maintai nence software then solve your problem
Jul 30, 2009 | HP DeskJet 5550 InkJet Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
Not dark enough
If you use a refilled cartridge all print quality problems should go back to the supplier of the ink.
Lexmark does not now and never has authorized refilled cartridges on their products for this exact reason.
Lexmark cannot guarantee the quality of the ink.
Apr 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
OKI MICROLINE  590 Matrix Printer Logo
74 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
