Question about Whirlpool GGW9250PL Gas Dryer
Dryer doesn't heat up - Whirlpool GGW9250PL Gas Dryer
  • Whirlpool Master
  • 3,051 Answers
Hello there
PLEASE READ THE ENTIRE SOLUTION
If your dryer doesn't heat, check these: Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Sep 28, 2010
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
248 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
