Question about Whirlpool Refrigerators
I have a whirlpool fridge freezer and there is too much ice in the freezer how do i stop that happening? i have scraped out the freezer with a plastic spatula and dont want a build up again
  • 828 Answers
If this is a model that is supposed to be frost free you have a defrost system problem. Scraping the ice off is only taking the surface ice off and doing nothing to remove the ice behind the panel that is stopping air circulation and heat from getting to your cooling coil for removal.
If you can located the defrost timer and rotate the clutch head screw clockwise very SLOWLY until you hear one click. This puts the timer into the defrost mode. Wait about 25 Minutes( Unit should restart after 18-22 minutes). If the unit does not restart automatically rotate the time to the second click. If you had to do this it means that the timer is at fault and needs to be replaced. If it does not defrost and the unit restarts automatically then your problem is on the defrost heater circuit.
Posted on May 24, 2008
My whirlpool fridge isn't cooling but freezer is
check if it has iced up around the air vents between the two halves as that will block airflow and warm up fridge. if it is is give it a good defrost to melt the ice and stop it from reicing
Feb 08, 2012 | Whirlpool Refrigerators
My whirlpool model #ET1FHTXMQ01 keeps freezing a sheet of ice on the bottom of the freezer and then I have to put a long narrow bowl at the back of the refrigerator to collect water that actually freezes. ...
We have had the same problem lately. We have called Whirlpool, looked all over the internet and asked several people but still cannot seem to find out why this happening. We constantly have to scrape the layer of ice off the bottom of the freezer and we also have to put a bowl in the back of our fridge where water continuously drips, if we don't, it floods our top shelves. I'm sorry I couldn't be much more help, but I wanted to let you know that you're not alone and that we have been experiencing the exact same issue. If I find out what's causing ours, I will be sure to come back and post it on here.
Jun 01, 2011 | Whirlpool ET1FHTXM Top Freezer...
Our freezer and fridge or not keeping cold enough
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor or back of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice build-up in the freezer of a Kenmore 19 (Top Freezer) refrigerator, and only 60 degrees in the fridge.
there is supose to be a switch or were the ice is making just figure out which way to turn it off or on. then turn it off and see if the ice stop making. if that doesn't work get a new frige
Jan 29, 2008 | Refrigerators
Whirlpool side by side fridge freezer
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
