Question about Maytag Dryers
When drying clothes blue spots appear on the clothes.Why is this happening and how can the problem be resolved.? Model ##DE303 serial #103284TP
  • Maytag Master
  • 3,051 Answers
Hello there:
If your clothes get marked or torn in your dryer, check these: Please read fully
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Posted on Sep 28, 2010
Dryer won't dry clothes
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
I have a blue haze across the bottom of the tv screen. About 1 1/2 inches tall. what causes this?
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
Aug 01, 2009 | Zenith E44W46LCD 44" Rear Projection...
Purple/white haze spot
Jul 09, 2009 | Zenith E44W46LCD 44" Rear Projection...
I have a Zenith d52wlcd and the screen is dark or excessively blue.
Jun 27, 2009 | Zenith D52WLCD 52" Rear Projection...
Rust spots showing up on the clothes?
Give the clothes more drying time and then remove them as soon as the dryer stops. Over the years, dryers get chipped inside and if damp clothing is allowed to lay on the chipped areas, rust spots will appear.
Also, If you have a lot of iron deposits in your water, you might want to put a filter in your line into your washer.
Feb 17, 2009 | GE DBSR453EBWW Electric Dryer
Blue Bands on sides of Zenith Projection TV D60WLCD
Dec 23, 2008 | Zenith IQB60M92W 60" Rear Projection...
Zenith D60WLCD Repair
Sep 21, 2008 | Zenith D60WLCD 60" Rear Projection...
Red spot, Yellow Spot, Blue scratch on the printing document
Hi hope you fine.
is it just a spot or a continous line kind of?
is just a spot check the service kit on the front door (ETB ) alighnment might be touching the prnt drum units.
Sep 21, 2008 | HP Color LaserJet 2600n Printer
I am looking for a tint trap for a Maytag dryer model #DE303 Series 07 Serial # 189625 XJ
Try partsstore.com as they do have your part in stock. I would phone them to make sure their website information is correct. If for some reason this did not help you you can try the chat portion of this website
Sep 07, 2008 | Maytag Dryers
Dryers Logo
55 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
