Question about Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX)
N.A.T Settings I have the netopia router as described below but i cannot get my N.A.T settings to change from "strict" to "open" for use on my xbox 360. I have already set up port forwarding and acquired a static ip address eg..192.168.1.136..what do i do on my network settings for my xbox? do i put this static ip address into my xbox 360 network setting? or do i leave it on automatic? thanks
  • manuelwxxw Feb 05, 2009
    omg dude i have tried EVERYTHIGN!!! literally... i have an xbox360 and a ps3 they both give me NAT strict... IM not good at this modem/router set up thing... please i begg for simple step-by-step explanation look my AIM is manny2206 or msn manuelwxxw@hotmail.com... i'll apriciate any help
    Scholar:
  • 43 Answers
So you want the public IP address that your Netopia router is getting to do a 1 to 1 NAT to the private IP address 192.168.1.136? Basically you want to bypass any of the firewall restrictions of the router?
The caveat with this configuration is that if you don't have any other public IP addresses for the actual Netopia router to use then all other devices on your network will now longer be able to access the internet through the router. Only if you have a public IP address that you can assign the router will it be able provide NAT and internet access to the rest of your network.
The 192.168.1.0 network is not routable on the public network. You need your entire network to NAT through your router using a public IP address.
You configuration will work if the Netopia router will allow a 1 to 1 NAT to another node on the network and allow NAT'ing for the rest of your private network concurrently. Of course you need at least (2) public IP addresses in the same subnet as well.
Hope this helps. Let me know if you need better clarification.
MO
Posted on Jul 13, 2008
I play call of duty and my NAT type is strict how can i change it to open?
you need to open the following ports up on your router
Xbox Live 360 requires you to forward the following ports: 53,80,88,1863,3074.
either open the ports for all devices or give your xbox a static ip and open the ports above for it.
Mar 14, 2011 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
I do not know how to change my NAT setting to open on Xbox Live
First of all I would just like to cover the basics of strict and moderate NAT settings. For those interested, NAT stands for Network Address Translation and is used to prevent problems with information being sent over a shared network.
With the XBOX 360, Microsoft have defined three categories of NAT. These are:
1. Strict
2. Moderate
3. Open
You can see the NAT level for your XBOX Live connection by going into your
1. System blade
2. Network Settings
3. Test Xbox Live Connection
For you question on how to open your NAT setting follow the steps below:
1. Type the IP address of your router in a web browser.
2. It will prompt you for a user name and password once connected
3. After logging in you will have a control panel of setting up different settings in your router.
4. The IP address, and default user name/password are different on every route
Note: 192.168.1.1 is a pretty common address for most routers.
5. Check the manual that came with your router for that info.
I also provided a few links below of password lists of different routers.
Click Here
Click Here
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
The NAT on my Netgear Dual Band WNDR 3300 is set to strict and is causing issues with XBOX Live, how do I change this setting to moderate, or below? I went to the website where you change the settings of...
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Aug 24, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
How do I get open nat settings for xbox live gaming? I have enabled the Xbox Live Games in the custom services but my nat setting is still strict!
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Jun 19, 2010 | Netopia (3347NWG-VGX) Wireless Router...
Strict NAT type on xbox live...eircom is provider, there router
Follow this link and it'll tell you exactly what to do if the router your using is an eicom netopia http://xbox360help.blogspot.com/2007/09/xbox-live-eircom-router-netopia.html
I had the same problem when i started 3 years ago. now i recently bought the new wireless adaptor and have one of the new routers from eircom and after 20 minutes during gameplay it disconnects me from xbox live.it is really startin 2 annoy me now. does anyone know what could be causing this to happen??
Jan 12, 2010 | Netopia 2247NWG-VGx Wireless Router...
How do i change my xbox nat settings from strict to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Dec 30, 2009 | Microsoft Xbox 360 Arcade
NAT settings are set to Strict
Go to this link this will help you with your problem.
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Once your on this page select the model of your router (look into Netgear).
On the next page select XBOX live. After this, this will give you instruction how to open ports for your xbox live.
Aug 04, 2008 | NetGear WGT624 Wireless Router
Xbox live
Hello!
Yes, the netopia router will work with xbox live. you just have to configure some settings on your router.
To configure your router for Xbox Live try the following steps below:
step 1: Open an Internet Explorer page. in address bar type your router ip address, That should take you to the Netopia's settings page
Step 2: On the menu to left click Firewall, set it to Low and Save Changes
Step 3: On the menu to left click Expert Mode, then Yes, enter Expert Mode
Step 4: On the menu to left click Configure, then Advanced, then NAT
Step 5: Where it says Service Name, scroll the list down to Xbox Live Games, click Enable and then Enable again
Step 6: On the menu to left click Configure, then Connection.
Step 7: In main page scroll down to the UPnP and put a check in the box. then Save
It should then restart the Netopia, and when it comes back on in a few seconds your XBOX LIVE should be good to go. If you are still experiencing problems accessing Xbox Live your Netopia may require a firmware upgrade.
May 10, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Change NAT to open
Here you go sir, follow the instructions in the link below and your Xbox live will report an OPEN NAT and it will fix your connection problems.
http://www.portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/Xbox_Live_360.htm
Hope this helps!
Feb 09, 2008 | Belkin (F5D7230-4) Router (587009)
Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX) Logo
408 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
