Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
Not enough water in the bowl - American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
  • 4,340 Answers
Check that the fill valve has a little plastic hose going into the overflow tube.
Posted on Sep 29, 2010
Tip
Empty Toilet a Bowl
Anytime you want to remove a toilet, you're usually facing the problem of how to get the water out of the bowl.
First, turn off the water
Flush, and hold the lever down until it has nothing more to drain out of the tank.
But then, you're still stuck with a full bowl of water.
Here's the trick
Fill a bucket with about 1 to 2 gallons of water.
Pour it fairly rapidly into the bowl all at once.
Because of siphon action, and nothing to refill, it will drain 90% of the water out of the bowl, leaving about a cup of water in the bowl.
If you have to have it completely empty, you can use a small hand pump, but in most cases, it's low enough for you to just carry out the way it is.
on Mar 26, 2010 | Plumbing
Water level adjustment
If it has a ballcock bend the ball upwards till you have a high enough water level
Nov 26, 2013 | Toto Home
How deep should a cats bowl be?
The depth of a cat bowl depends on a number of variables, most importantly the number of cats using the bowl. I suggest placing a few bowls in various places around the house. This way you can be sure that each of your cats will have water when they need it. The bowl should be large enough that your cats whiskers do not touch the sides of the bowl.
Aug 26, 2012 | Alessi Cats
What types of materials are cat bowls made from?
Most cat bowls are made from one of three materials - plastic, ceramic/glass, or stainless steel. I recommend a ceramic/glass bowl. Many plastic bowls harbor bacteria and stainless steel bowls (although they are best for keeping water cool) are not heavy enough and will be easily tipped over by your cat.
Can't get enough water in toilet bowl to flush the waste
Adjust your tower to let the bowl fill up more.....google your problem if you dont understand...depends on what kind of tower you have....should have teeth on the tower itself to make it fill more...try pulling up on the float...
Mar 15, 2012 | Jacuzzi Bath Perfecta EZ33 959 White round...
There is not enough water in the bowl, Can I raise the water level in the bowl
no it is predetermined and can not be changed. How ever you may be able to ingrease the water level in the tank by adjusting the float ball.
Just to be sure the ballcock is putting the max amount of water into the bowl mark the level of the water in the bowl with something and pour some water into the bowl and see if it stays at that level.
Feb 03, 2011 | Home
Macerator keeps going off even when not flushed.
Water pressure makes the unit turn on and off. It will only activate on it's own when enough water pressure is present. Most likely it can be water leaking from the toilet tank into the bowl, and from the bowl into the pump. Or could also be that waste water is slowly draining back into the pump through the check valve on the discharge elbow, creating enough water pressure that it will make the unit kick on and off.
Aug 06, 2010 | Saniflo & Saniplus& Macerator Pump
When flushing toilet, water spins in bowl but does not flush away. Have used plunger to no avail. However, if I pour a 3 gal bucket of water into the toilet bowl, it flushes just fine and the water level...
Alot of times this problem occurs when there is not enough water in the tank behind the seat and bowl. Lift off the tank lid and see how much water is it, It should be near full.If it is not your problem is not enough water.
Feb 21, 2010 | American Standard 2071.016 Heritage One...
When flushed, not enough water flow to empty sides and waste
make sure water level is sat at factory settings. there should be a black line that reads WATER LEVEL. If this is not the problem. then you have calci buildup. get a gal. of muratic acid,plunge all water out of toilet bowl. then dump in at least 1/2 gal. let set over nite. with water turned off. get up turn on water then flush. You mite have to do it twrice. hope this helps you.... duane.
Sep 28, 2009 | Kohler Barrington Pressure Lite Elongated...
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
175 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
