Question about Panasonic PT-D3500U Multimedia Projector
Panasonic PT - D3500U has the power button turn green then starts blinking orange. What is the problem and what needs to be fixed. The lamp and temp lights are not on.
  • 4234 Answers
SOURCE: cannot access menu screen on Panasonic PT-D3500U projector
If memory serves me correctly, there is an OSD button on the projector itself. Press that once. You may have turned off the OnScreen Display feature. If that fails to resolve the problem, please let me know and I'll look up your specific model.
Dan
Posted on May 28, 2008
SOURCE: panasonic pt ae900 wont fire up
First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
Let me know if this worked.
Posted on Dec 27, 2008
SOURCE: Panasonic PT L501u Replacement Lamp
panasonic projectors , even if the lamp has reached end of life gives u 10 minutes to reset the lamp counter
so when u replace a new lamp, go to options, lamp counter, reset & press stanby button for confirmation!
thats all the unit powers off & when u check the lamp counter , its shows 0
u r done!!!!!!
Posted on Feb 08, 2009
SOURCE: Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Posted on May 03, 2010
  • 567 Answers
SOURCE: after a few seconds the
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Posted on Aug 03, 2010
    I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
    If the LAMP INDICATOR flashing red then.
    Problem: Lamp circuit failure
    Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
    Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
    I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes orange...
    Welcome to fixya
    Hello
    I have a solution for this
    Press Ok, Accept or replay so we may get started
    Your pre-solution is coming up shortly
    PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
    My name is Bruce
    If PT-D3500U lamp won't strike (bulb has been changed with no effect), how can you reset the lamp timer to get the unit operational?
    Instructions are listed in the owners manual (http://service.us.panasonic.com/OPERMANPDF/PTD3500U.PDF) on pg. 46.
    Press the "POWER" button (or the POWER OFF ( I )
    button on the remote control) so that a picture is
    projected onto the screen.
    Press the "MENU" button to display the MENU screen,
    and then press the and buttons to move the
    cursor to select "OPTION2".
    Press the "ENTER" button to display the "OPTION2"
    screen, and select "SYSTEM INFORMATION" with the
    and buttons.
    Press the "ENTER" button.
    The SYSTEM INFORMATION screen will be displayed.
    Press and hold the "ENTER" button on the projector or
    the remote control for approximately 3 seconds.
    An item "LAMP TIME RESET" will be added.
    Press the ENTER button, and when the "LAMP TIME
    RESET" display flashes, press the ENTER button again.
    The used hours of the lamp unit will be reset to zero.
    Jan 14, 2011 | Panasonic PT-D3500U Multimedia Projector
    Panasonic pt-43lc14 won't turn on
    Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
    Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
    Power indicator light blinks orange times
    sounds like the lamp faceplate is not screwed back in properly
    Aug 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    My Panasonic PT- 50LC13 doesn't turn on
    Your service manual on page 82 steps you through decoding the blinking
    1) there are two lights on the front near the reciever of the remote signals (Temp indicator and Lamp Indicator)
    2) If the Temp indicator is on then they recommend you contact a service center
    3) If the Lamp indicator is on and the power light stays on (no blinking) then you need to replace the lamp. Otherwise it says to contact the service center.
    4) Counting blinks with the lamp indicator (1 every 5sec - lamp will not light or is abnormal, 2 every 5sec - lamp voltage is abnormal, 3 every 5sec - lamp temp is too high, 4 every 5sec - other error)
    Apr 26, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    Panasonic projection TV power blinks in orange 5 times every 5 seconds
    did you ck the lamp,  can you ck voltage to ballast should be around 300 volts
    Oct 23, 2007 | Panasonic PT-50LC13 50" Rear Projection...
    Panasonic PT-D3500U Multimedia Projector Logo
    173 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
