Question about Acer AL511 15" Flat Panel LCD Monitor
Acer AL511 15" I need advice in repairing this lcd monitor. I purchased used, faulty 15" display for reading email. Symptom was display flashes on, pictures comes, click, goes off. This repeats endlessly. I repaired this symptom in the past by replacing faulty capacitor on power board - in another display. Now I have replaced all 5 caps this power board has and symptom remains. Display green light comes on, picture comes for 1/2 second, backlight flashes on and off. green light goes off. Brand model Acer AL511 15" PK100007500 REV.1 - power board do not know if any help but images of power board http://ekse.pp.fi/acer/ Testing voltages from powerboard to mainboard, did not find a 12V rail. With power on only 3 5v and 3v. Yellow wire- which I suspect should be 12v reads 0.3 steady.
  • 6 more comments
  • Ekse Sep 28, 2010
    I found service manual for hitachi CLM154XW that uses same powersupply I've posted it on my server at http://ekse.pp.fi/d15d1798-e3ed-4df3-8fe...
    Unfortunately troubleshooting in this service manual is in the order of REPLACE BOARD AND TRY AGAIN.
    Please note that I'm not going to replace whole boards as the price of the display was only 4 euros, it is not worth it to spend 50 on a new power board.
  • Ekse Sep 28, 2010
    Haven't received any solution or suggestions Yet.
    Few notes. I noticed from the service manual that there possibly is no 12v rail that goes from psu to mainboard - looking at the pinout of the connector.
    CON3
    Pin NO Signal Comment
    1,2 Vcc +5V
    3,4 GND Ground
    5 Ven Back-Light ON/OFF control. Low active
    (ON: 0~1V, OFF:3~6U)
    6 Mute Audio control signal
    7 Vhri Brightness control (min~max)
    *For Hannstar pannel: 0.45~2.7V
    *For AU Pannel: 0.45~3.3V
  • Ekse Sep 28, 2010
    Hello Micro, Do you have any lcd monitor repair experience?
    The problem and question is on the first - original comment.
    "Symptom was display flashes on, pictures comes, click, goes off. This repeats endlessly. I repaired this symptom in the past by replacing faulty capacitor on power board - in another display. Now I have replaced all 5 caps this power board has and symptom remains. Display green light comes on, picture comes for 1/2 second, backlight flashes on and off. green light goes off. "
  • Ekse Sep 28, 2010
    Question: How do get the monitor working normally. What is faulty? What needs to be replaced?
    -- Capacitors have been replaced from the powersupply, problem remains.
    -- I've tried another set of backlights -- did not help
    -No Not the whole boards, as I said in my comment, it is not worth it.
  • Ekse Sep 28, 2010
    I appreciate the answer, but unfortunately it is not worth 5$ (of witch you would get 2$)
    also I do not agree with having to replace all the major parts, (PSU/Inverter, Mainboard, Backlight)
    It is clear that backlight tubes are ok, problem appears to be either psu or mainboard. Which can be repaired.
    I purchased this faulty monitor to repair myself, I'm not going to scrap it after 6 hours of receiving it.
  • Ekse Sep 28, 2010
    Rulds, the inverter board is part of the powersupply which cost 45$ shipping international. As I said this is not worth it considering I purchased this faulty display for 4$.
    Sorry but you did not offer anything useful I can't accept your solution, it does absolutely noting to help me get forward with this repair.
  • Ekse Sep 28, 2010
    So far the "advice" has been useless, quick, few line answers, Hoping to get a real professional with LCD repair experience to answer this one. This will probably end in a refund if these few liners keep on coming.
  • Ekse Oct 11, 2010
    Micromatikal, for begging a 4 star rating, you deserve the 1 star. I'll surely post it to you again if you have someone remove it from your account.
    President:
  • 2,777 Answers
Ok so what is your question exactly, I do not see a question in there?
Posted on Sep 28, 2010
  • 10 more comments
  • Tim Grayson
    Tim Grayson Sep 28, 2010
    Oh I see lol, and you are a fellow expert as well :) I have repaired LCD monitors yes, but am unsure of what this issue is. Sorry about the confusion there :).
    Tim
  • Tim Grayson
    Tim Grayson Oct 11, 2010
    Please if possible come back to the question here and rate it 4 thumbs. It looks like the answer helped you, but for some reason it doesn't rate it 4 thumbs unless you come back a second time and specify 4 out of 4 thumbs. I hope you will do this for me. Thanks Tim
  • Ekse Oct 11, 2010
    Wtf you think that you actually helped me?
  • Tim Grayson
    Not necessarily, but the 1 thumb is killing me here. Seriously even bumping it to 2 would be a great benefit :(, I wasn't trying not to help you that's for sure.
  • Ekse Oct 11, 2010
    To me it seems you placeholded in as the first poster just to get the 2$ incase no solutions where accepted. Thats why I made sure I got refunded so you wouldn't get the 2$ for playing dumb. No you offered noting to me, your not getting a 4 thumb rating. Welcomejee got his 4 thumbs because he was helping me over email for free. I didn't just give him 4 thumbs because he posted something silly.
  • Tim Grayson
    lol, that's fine. I appreciate you at least looking at it here. I understand, no worries :). Just going through some of my lower rating posts and trying to get them up a bit higher. I really wasn't trying to upset you or anything.
    Try to cheer up a bit over there though,
    Tim
  • Shahid Electronics
    Shahid Electronics Oct 12, 2010
    Sheesh, my silly comment was for compacitor king only. Micro, what is your best area of expertise by the way? mind to introduce yourself mate?
  • Tim Grayson
    Tim Grayson Oct 12, 2010
    Hey there, sorry, didn't mean to get you involved here, not sure what you mean though. It was Ekse that referred to your comment, not me.. What do you mean?
    Thanks
    Shahid Electronics Oct 13, 2010
    it was simple and friendly question. ok, never mind.
  • Tim Grayson
    Tim Grayson Oct 13, 2010
    No problem, I just didn't understand. I have expertise in Computers, TVs, general electronics, audio equipment... May as I ask why you ask? What was the "Sheesh" in reference to? Sorry if I upset you somehow. Please to meet you... but I am still confused lol :) Please let me know what you mean by introducing myself? I don't think many people will see the page here..
  • Tim Grayson
    Wow I had some typos there lol, sorry about that. Just a little confused still... I'd be glad to introduce myself... Would you like to know more? Please help me out here..
    Thanks
  • Tim Grayson
    Tim Grayson Oct 14, 2010
    Hey man, I hope I didn't upset you somehow. Someone has been going through my ratings and purposefully rating me lower / rating no on my answers for some reason. I was just trying to help bump up my rating. Have never been anything but helpful to people and it's quite disheartening :(.
  • 10,594 Answers
Did you checked bulged compacitors in main board of tv?
Posted on Sep 29, 2010
Testimonial: "Wunderbaum!"
    Top Expert:
  • Acer Master
  • 76,691 Answers
You will not be able to repair this for less than cost of a new monitor, just bought one, a 20 inch and was only $98.00 after rebate, the brand was ASUS.
    President:
  • 2,047 Answers
This is not a solution as i cant give one which i can guarantee. I would advice you scrap the monitor this is because due to my experience once flat panel monitors begin to show signs and symptoms such as this regardless of what repairs are effected on them a different problem just happens to come up.
The only sure way to get this monitor functioning fine is if all the major components in it are replaced and this would usually cost more than a new monitor. Sorry for my response but it is a honest opinion.
Hope this solution is helpful?
  • Acer Master
  • 3,866 Answers
The issue is one of the inverters that is faulty you would not be able to tell by voltages. The only way to tell is with a test board that you would not have otherwise only repair shops would have a test board.
I know this might not be much of any help but my recommendations would be replace the inverter board there pretty darn cheap and will not break the bank.
please do click the accept button for my efforts.
Screen is black
If the notebook appears to boot up and the LED hard disk light flashes then :-
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 13, 2009 | Acer Aspire 5100 Notebook
Acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Aug 14, 2009 | Acer Aspire 5610-4648 Notebook
Acer 4520g minitor blackout
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 14, 2009 | Acer Aspire 3680 Laptop
A three inch verticl faded portion of screen
You most likely have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Aug 06, 2009 | Acer TravelMate 2300 Notebook
Acer aspire 4720z model laptop having dim resolution of monitor
The fault could be a faulty CCFL lamp or inverter.
Check out
www.lcdparts.net
Jul 23, 2009 | Acer Aspire 4720 Notebook
Computer is on, screen stays black
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 04, 2009 | Acer Aspire 3690-2196 Notebook
My monitor screen keeps flickering on and off. is there something that can be done to fix this?
Check out
www.lcdparts.net
Jul 02, 2009 | Acer Aspire 4520-5803 Laptop
Monitor
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 25, 2009 | Acer Aspire One PC Notebook
My acer aspire 4320 have no light in the display
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 26, 2009 | Acer TravelMate 4320 Notebook
MY ACER LAPTOP SCREEN TURNS ON BUT THE SCREEN IS BLACK
To determine if you have a video card problem or the LCD screen is at fault.
Connect an external monitor to the video port on the laptop and boot up your laptop, if you get a display on the external monitor then your video card is OK and you have a faulty LCD.
When you power your laptop without an external monitor and have a close look at the LCD screen at and you see a slight image then the fault is with the backlighting panel. This fault could be a faulty inverter or a faulty CCFL backlight lamp.
Defective CCFL backlight may has the following symptom:
The inverter can be easily replaced so can the CCFL lamp (but requires a lot more work)
For info on parts and repair service goto www.lcdparts.net
Mar 02, 2009 | Acer Aspire 5610-4648 Notebook
Acer AL511 15" Flat Panel LCD Monitor Logo
376 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
