Question about GE Advantium SCA1001SS Convection / Microwave Oven
Microwave portion malfunction
I have an SCA2001BSS 30 and the microwave portion does not work. The main fuse was blown due to a power surge.
  • 2 more comments
  • Seadog39 May 24, 2008
    All of the other functions - the upper and lower ovens work properly.
    It was the fuse inside the unit
    All functions of the Advantium work except the microwave portion. When I attempt to use the microwave portion it sounds like it is running, the table turns, the fan runs. The other two portions cook properly - the upper and lower oven portions.
    Thank you. We have checked the wiring and it appears all ok. Whgich parts do you think may have tobe replaced in the microwave portion?
  • GE Master
  • 13,433 Answers
The fuse in the oven was blown or the main fuse in the house?
Posted on May 24, 2008
  • 1 more comment
  • Ekse May 24, 2008
    ok, you will have to replace a few parts from the microwave and check the that the wireing is in good condition. The unit that actually heats the food may be broken.
  • Ekse May 24, 2008
    Hard for me to say, as I don't have the service manual with the part diagram.
    Heres a website which sells parts for GE microwaves
    Have a look here
    http://appliancehelp.com/Search_Models.a...
    Ask them with a email Im sure they can direct you. Unless you want to send the microwave somewhere to be serviced by a professional?
  • Ekse May 24, 2008
    heres a link to the front page also
    Sergeant:
    Champion:
  • 230 Answers
Change the fuse first and check and also check whether the connections inside are proper or not
  • 1 more comment
  • balachander megavarnam
    balachander megavarnam May 24, 2008
    tell me properly whether it can heat or cook anything.tell what it is doing?
    if it is not heating may be the problem will be with the thermostat
    check the thermostat and then try .............................please dont forget to rate the solution
    Genius:
  • 3,422 Answers
Did you mean that the microwave oven won't turn on at all?Did you try replacing the fuse?
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
Fuse problem
I very much doubt it, chances are it has blown a capacitor or something along those lines, however the fuse in the mains plug should have blown before any damage was done, that's what they are there for, so if the fuse in plug is ok I think your microwave has had it.
Nov 08, 2013 | General Electric PVM1870SMSS Microwave...
Repair
please see this details and fix it. God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models)
Jul 09, 2013 | GE Advantium SCA2001BSS Microwave Oven
MICROWAVE PROPLEM
follow this next steps, use the VOM, and fix it. God bless you
5. Clock needs to be set before other functions will operate (some modelsbcd93e93-ccee-45ab-ba5c-70967b1ff19b.gif
Jun 11, 2013 | Sharp R-1874 Convection/Microwave Oven
Blows a fuse when you try to use microwave
follow the next steps, and use the common sense: God bless you
5. Clock needs to be set before other functions will operate (some models).
Aug 03, 2012 | Tricity Bendix TMC209 Microwave Oven
FUSE BLOWN PART WB27X10388
http://www.appliancedepot.com/parts/parts-used/fuse-microwave-ge-wb27x10388-jvm2070sk02-jvm1871sh02.html
That is a supplier for you.
It is a semi surge sand filled ceramic fuse and the rating will be stamped on the end cap.
Hope that helps.
Jan 03, 2011 | GE Advantium SCA2001BSS Microwave Oven
Start button doesn't work for all microwave functions--as well as timer--fuse is ok
Possible causes:
Dec 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I had a power surge in the house and now my GE sensor Microvawe is stone dead. Any ideas.
It is possible the main fiuse in the Microwave has blown. Sometimes this is a special ceramic fuse and costs around $30. But to get to the fuse you have to remove the outer cover of the microwave( unplug it first) It is usually located on Top left side of the unit. Once replaced it should return to service.
Please rate our help++++Thanks for using FIXYA
Oct 12, 2009 | GE JVM1630 Microwave Oven
No power to microwave?
blown fuse take outer casing off and replace the blown fuse.
You can use a piece of tin foil around the fuse until you are able to replace the fuse.
Sep 07, 2009 | Maytag Appliances Over-the-Range Microwave...
My maytag microwave lost power
There is always a fuse inside a microwave.Sometime this has only blown due to a surge,and upon replacing, the microwave will continue working.If it is something worse the fuse will continue to blow.In this case it could very well be the transformer,but there are other possible causes as well.(for example the control board or a short.)
Jun 24, 2009 | Maytag MMV1153A Microwave Oven
GE Advantium SCA1001SS Convection / Microwave Oven Logo
170 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
