Question about Google Computers & Internet
I am unable to create a company after installing tally 9 v 2.14 on my system. On clicking create company option in gateway there is an error message sayin\r\n " Exiting Tally! Error in TDR. 'Part:Basic Company' Insufficient Height to Allocate" please help
Posted on Jan 19, 2011
Unable to create company path c\tally.erp 9\Data\10005
Does your user name and password have administrative rights on the computer? If not then you may need try with a user that does. I have run into some software that will throw a similar error if the folder already exists.
Jun 26, 2015 | Tally Office Equipment & Supplies
Error in tally 7.2
What Operating System are using?
A safe solution would be to go to your Control Panel, from the Start Menu. From there, go to "Add/Remove Programs", and find your software application. See if there is a "repair" option next to it, and if so, run that.
Unless you have the original discs and product key for this software, please don't uninstall it - it will be difficult to get it back.
If this does not help, or you don't see a "repair" option, please post back with more information.
Apr 10, 2008 | Computers & Internet
Tallyerp 9 memory access violation
If there are any user defined TDLs defined in the Tally.ini file set Default Companies to NO start Tally and check.
If the problem persists
Increase the screen resolutions to 16 bit high color small fonts, Load Tally and check.
Delete the printer drivers available in the Printer panel. Execute Tally. If this resolves the issue you can then re-install the printer drivers.
If the difficulty persists
After checking above-mentioned in case the difficulty persists please check the following.
Check for viruses in the system
Delete the Tally.sav file and check
Re-install Tally in a different folder and check
Disable the real time protection of the Anti Virus Software
Incase the problem persists please send an email to support@tallysolutions.com .
In case the problem is rectified when Default Companies is set to No in Tally.ini it indicates that the default company is corrupted. In such cases please follow the steps mentioned below
Take a backup of your company data
Execute Tally 9
From the Company Info Menu press Ctrl Alt R.
The Rewrite company screen is displayed. From the List of Companies screen select the Company in which you are facing the difficulty. The screen Rewrite Yes or No is displayed. Press Enter to re-write.
The error message indicates a data corruption. Please restore an earlier data backup which did not have this problem and proceed.
If you do not have the Backup then create a copy of the existing data and rewrite it by clicking Ctrl+Alt+R before selecting the Company.
Before rewriting ensure that the Company you wish to rewrite is not in use on any of the nodes and the command has to be applied before selecting the Company.
The data preferably should be available in the local hard disk. Ensure that you create a back up of the data in the the hard disk or a medium like CD.
Check http//www.tally9.info
http//www.tallyerp9.com
I found this howto here: https//answers.yahoo.com/question/index?qid=20100521043632AAsKkQs
Mar 31, 2014 | Computers & Internet
Tally 5.4 error failed to open the company
i using tally 5,4 if it any company open means they will come FAILED TO OPEN THE COMPANY,pls tell any solution
Dec 14, 2012 | Computers & Internet
Exiting tally error contact tally solutions, unable to create company in path'e:\tally\data\10002'
Nov 01, 2012 | Computers & Internet
I have installed Tally 9 in my laptop. The operating system is Windows 7. Now when I try ti create a Company, it gives error massage " Exiting Tally ! Error in TDL. Part:Basic Company, Insufficient...
on any pc if you get error "insufficient height to allocate".. then just set the dpi of your pc/laptop to 100%, (you can adjust dpi from display settings) and try to use tally, this might solve ur problem.
if the above doesn't solve ur problem, then go to screen resolution setting and select 800 x 600 resolution. this might solve ur problem to most extent.
if still u are facing the prob then go to display setting of windows and reduce the font size of menu, message box, active title bar, non-active title bar and etc... reduce fonts of all..
tats all
May 02, 2011 | Computers & Internet
Error message : File is damaged. Rewrite!
Step 1: Start Tally.
Step 2:
Step 3:
Tally asks to select the company to rewrite. Select the desired company to rewrite and then press Enter key.asking-tally-to-rewrite-a-company.png
Step 4:
Rewrite confirmation will be appeared on the screen, press "y" to start rewriting process.rewrite-confirmation-in-tally.png
Step 5:
After rewriting the data Tally creates Tally.rew file in Tally folder.open it in any text editor and go through it about the corrupted data.rew-file-in-tally.png
Sep 15, 2009 | Computers & Internet
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
ERROR IS (MEMORY ACCESS VOILATION C0000005)
I AM FACING LOT OF PROBLEM DUE TO ABOVE SAID ERROR ALL THE OTHER SOFTWARE IS RUNNING PROPERLY EXECPT TALLY 7.2
TALLY IS OPEN UPTO SELECTION OF COMPANY AFTER THE COMPANY SELECTION AT GATEWAY OF TALLY IT SHOWS THE ERROR MEMORY ACCESS VOILATION C0000005
Nov 12, 2008 | Tally Line Matrix T6050 Printer
Computers & Internet Logo
990 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
