Question about Dell OptiPlex GX280 PC Desktop
Fan/modem/or harddrive just won't shut off. sounds like an engine reving up constantly. Is there anything to be done? Help Me Please
Frequently, this sound is caused by dust inside. Unplug the machine, open the cover and apply Dust Remover. The machine should much quieter.
Posted on Sep 30, 2010
My wife was mowing with our Husqvarna ride on CTH2038 and it started reving really fast so she disengaged the deck and ramp the throttle back to min but it kept reving so she shut it down with the key
Best thing I can recommend is to carry it to a trusted repair shop for them check it out for you.
Sound like governor control came loose or the governor self destructed. Without the age of the mower don't if the warranty will cover the repairs but the engine will need at least repaired if not replaced.
Oct 19, 2014 | Husqvarna Garden
My engine fan keeps running and won't shut off.
try to clean the fuse box and keep it dry from humidity
Sep 13, 2017 | 2001 BMW 325Ci
Reving sound in car when driving
It sounds like the engine driven cooling fan clutch is locked up on this vehicle. have it checked by a local shop.
Sep 06, 2012 | Cars & Trucks
Rattle at 4000 constant reves
from what you describe it sounds like cam chain,use a long screwdriver ( or something like ) as a stethoscope and touch the engine with metal end, put the screwdriver handle to your ear and locate where the noise is coming from ( mind you dont get burned or anthing caught in moving parts )
Oct 09, 2009 | 1989 kawasaki ZXR 400
Laptop shuts OFF on it's own
Laptop fans DO NOT run constantly. They only turn on when booted up and once the laptop has reached a certain temperature. You should probably time how long for a shutdown, record your results. Let laptop cool for 10-15 between attempts. If it takes approximately same amount of time to shutdown between attempts it is very possible its overheating.
Other things like Viruses, software conflicts, and Harddrive problems can also be the culprit. take a look at the administrator event logs for any clue there. Event logs are in control panel under Administrator Tools.
I don't recommend trying to fix any overheating issue you may have, as that would entaiil disassembling your laptop. Unless you have a bit of experience in this, I would take it to a good repair shop.
Hope this helps you some. If so please rate my solution.
May 10, 2009 | Dell (6F858) Cooling Fan
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
2005 Polaris Sportsman 700 twin coolant fan will not shut off
Your thermostat is bad. The default position is" on" so that you don't burn up your engine if it goues out when your running.
Please rate if this helps-
Mar 23, 2009 | Polaris ATV
The crazy blue box
crazy stuff here.. it might be the display or the harddrive check the pins on the display cable. how old is the PC? and have you added anything to the computer to damage the motherboard? I suggest doing a system recovery it might solve the promblem.
Sep 12, 2006 | E-Machines eMachines Refurbished EMA...
Dell OptiPlex GX280 PC Desktop Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
