Question about Nikon N65 35mm SLR Camera
FEE reading on n65 camera
Will not autofocus and flashes fEE
  • 667 Answers
Make sure your lens has the aperture ring to the minimum f-stop number, i.e. (f-22, f-32, largest number) and the focus switch set to 'S' or 'C'
Posted on May 24, 2008
Nikon N65 won't take a picture
If you have the lens set to the lowest number, you should be seeing a FEE error on the display. The lens needs to be set to the highest number, typically 16 or 22.
Feb 13, 2013 | Nikon N65 35mm SLR Camera
I've been reading all the messages and Im getting the same FEE code. It works while manualy putting it on the F22 aperature setting. But I was wondering why I can no longer manualy control my aperature...
Leave the aperture ring at f/22. You can then control the aperture from the camera body, the same way you would with a lens without an aperture ring.
Jan 05, 2011 | Nikon N65 35mm SLR Camera
What does fee mean ?
It means that you have fitted a lens which has a manual aperture control and have not turned the aperture ring to the smallest setting (highest number). The F65/N65 controls the aperture from the camera body instead, via the command wheel.
If this is not the answer, then the tiny switch at about the 7 o'clock position (as you look at the front of the body lens mount) which senses that the aperture has been set to minimum has either failed or has sheared off completely. If so, your camera is totally uneconomic to repair as it's easy enough to get perfectly good N65/N75 and similar models for nothing via your local Freecycle and Freegle groups.
Sep 20, 2010 | Nikon N65 35mm SLR Camera
Nikon N65 won't take picture
The problem is, that you have a lens witch has an aparture ring on it and some exposure modes needs it to be fixed on the smallest aparture (e. f22). When its done the camera should not say fEE no longer.
May 15, 2009 | Nikon N65 35mm SLR Camera
N65 built-in flash not working
Yes, you can. Unfortunately Nikon is so backed up with repairs, your camera will probably take a few months to get it back and cost you more than you want to spend. The labor is what is so much. Just like fixing your car a shop. Your camera probably has a flash sensor that has worn out or needs to be re-callibrated is all. I have a friend who fixes cameras.
http://www.cameradr.com/
Check it out
Nate
Jan 05, 2009 | Nikon N65 35mm SLR Camera
Camera wont let me take any pictures it just says FEE?
That usually means that the lens you have mounted on the camera is not set to its smallest aperture (ie 22). It needs to be set that way so that the camera can control the full spectrum of aperture positions when shooting in one of the auto program modes.
Dec 28, 2008 | Nikon N65 35mm SLR Camera
Flash
You might not have your lens set to the minimum aperture setting (the largest number) if it is a non-G lens.
Nov 29, 2008 | Nikon N65 35mm SLR Camera
Nikon N65 Unable to take picture
Hey colettekm,
What this message should mean is that a non G-type Nikon lens is being used and its aperture is not set to smallest aperture which would be the largest number on the aperture ring on the lens. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 24, 2008 | Nikon N65 35mm SLR Camera
FEE signal
You can only change the f-stop using the camera's controls. Trying to change it on the lens will not work with the N65
Mar 19, 2008 | Nikon N65 35mm SLR Camera
N75/ fEE
The camera requires you to set your lens aperture at the minimum setting, usually orange coloured. I.E. f22 f32. Nikons control the aperture through the camera, not setting the ring manually like old style SLR's
Feb 25, 2008 | Nikon N75 with 28-105 lens 35mm Film...
Nikon N65 35mm SLR Camera Logo
121 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
