Question about Frigidaire Dishwashers
Our Frigidaire panel is flashing : washing drying er clean S
SOURCE: Frigidaire PLD3465REC dishwasher error??
Hi, I am having the same problem you describe above with the model nr PLD3460RDC1. Were you able to find out what it was? Thanks so much!
Posted on Aug 18, 2006
SOURCE: Er message on panel of Frigidaire GLD3450RD
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Posted on Jan 03, 2008
  • 93 Answers
SOURCE: Hello. I have a Frigidaire
This is going to be a electronic control problem. Part #154540101. art can be purchased online at foxparts.com
Posted on Jul 17, 2008
  • 409 Answers
SOURCE: Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Posted on Oct 02, 2008
SOURCE: Error Message 'Er' on frigidaire dishwasher
I had the same problem. I pressed the "Start Cancel" button, kept it down, then pressed "Rinse Only" button. The display then went clear. I pressed "Start Cancel" again, then "83" showed up on the display. I let it run its cycle, then it corrected itself. A little scary, but it worked. This answer board is great!
Posted on Feb 22, 2009
FPHD2481KF1
Thank you for your post, nansie Bento!
Based off the information you have provided your Frigidaire dishwasher is flashing "ER clean S". That error stands for a membrane switch failure, which means that your main control board has detected a key stuck or pressed in for more than a minute. You can push all the buttons down to attempt to locate the key that is stuck. It could be a potential issue within the keypad or main control board. You could try to clear the error code by resetting your appliance, which can be done by flipping the household circuit breaker for roughly ten minutes. Hopefully this is helpful. -Matt
Aug 24, 2014 | Frigidaire Dishwashers
4yr old Frigidaire, green flashing ER light and red flashing washing/drying and red flashing clean/S. model# PLD 4555RFC3. Also green flashing china/crystal and red flashing rinse/low, start/delay doesn't...
Good Afternoon Sandra, thank you for your question!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Sep 21, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
ER code, flashing touch pad selections.
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Jan 04, 2013 | Frigidaire Dishwashers
"ERR" is flashing and it makes sounds like it washing dishes.
Hello derekwaynemo - Could the dishwasher be flashing "ER"? If so, it typically indicates that the unit has shorted out the control panel. This can happen by excess moisture getting into the control area. Let the unit dry for 24 hours with no use, and see if the display error code erases itself. If it does not, this unit will require the repair of a professional to move forward accurately.
Dec 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
I have a Frigidaire model#PLD4555RFCO the er code and the washing and drying and clean and S lights are on and blinking on the display. have any ideas what the problem is?
Hi
"Er Clean S" is a common error with Frigidaire which means shorted keypad. The issue is with the touchpad/keypad that should be replaced. However, before replacing the keypad you can unplug it and take it apart completely and use a hair dryer to blow some warm air on the keypad assembly to blow the moisture off. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Frigidaire Professional Series 24 in....
Frigidaire gallery FGHD2433kw1 error washing clean drying ER s ...
The ER error code means the touchpad is defective..sometimes that can be just a loose ribbon cable connection to control board. or if that seems tight the touchpad which is part of the console should be replaced
Aug 23, 2011 | Frigidaire FGHD2433K 24 in Builtin...
Error message "clean S"; flashing
Hi
Daniel
Jun 18, 2011 | Frigidaire PLD4375RFC Dishwasher
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Jan 01, 2009 | Frigidaire PLD4375RFC Dishwasher
hi there,
thanks
Oct 02, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwashers Logo
94 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
