Question about Novatel Art Explosion Scrapbook Factory Deluxe 4 Full Version for PC (SJWTNRS)
Scrapbook Factory 5 I can't get my 8 1/2X11" pages to print borderless. I have followed your directions. I go to page setup and set buttons to 0 then OK. I have pulled the page to the outer sides even though it looks OK on screen. Set up my printer to borderless (which works fine in other programs) and click OK. I go to preview and it shows 1/4" border on the top and sides and 1/2" on bottom. What am I doing wrong? It worked on Deluxe 4. Thanks
2 Suggested Answers
  • 26 Answers
SOURCE: I can not get my pictures to upload to scrapbook
go to windows update and check for software update's,seam's you have a compatability issue with the earlier software, i know xp has a compatability program that lets you run programs in a earlier os formate to make the earlier programs run in the later OS'S Hope this works Steve
Posted on Oct 01, 2009
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Selecting Scaled Printing changes the printable area.
Hope this helps
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
Before printing, configure the page setup on the application where you're printing from. Go to File -> Page Setup -> select Landscape orientation -> hit OK to save the setting.
To print your sketch, go to File -> Print -> Preferences/Properties -> from the Page Setup tab, select Landscape orientation -> from the Print Layout tab, select Borderless -> click OK to save the settings -> click OK to start printing.
I hope this information has been helpful.
If you need additional assistance, please contact Lexmark technical support.
Nov 24, 2010 | Lexmark X2580 Wireless All-in-One InkJet...
Borderless Printing Doesn't Happen
hi as you have set border less printing in publisher and on printer, have you adjusted the layout guides? on the blank page go to arrange, then to layout guides, adjust the numbers to atleast 0.25 (lowest it will go) and save then try printing, the but remember, hp still has a border due to the print heads position they do not travel over the print area like some printers do, you will always get a small white line no matter what...hope this helps
May 24, 2010 | HP Office Equipment & Supplies
Getting a borderless print
Try this if that helps:
Using iPhoto to create borderless prints To use iPhoto to create borderless prints, please follow all of the steps below:
  1. While logged in as an Administrator, install the latest Canon printer drivers onto your computer (with Mac OS X v10.2 or later as the operating system) and select the appropriate printer as the default.
  2. Launch iPhoto.
  3. From iPhoto, select and open the image you wish to print. (Please refer to the Apple web site for instructions on how to use iPhoto.)
  4. When you are ready to make a print, select from the Menu Bar 'File: Page Setup'.
  5. The Page Setup dialog will appear.
  6. Select the following settings:
    1. Settings: Page Attribute
    2. Format for: <Select the Canon printer you wish to use>
    3. Paper Size: 4x6 (borderless)
    4. Orientation: <Select the matching orientation>
    5. Scale: <Select the appropriate scale>
  7. Select 'OK' and the Page Setup dialog will close.
  8. From iPhoto, from within the Constrain section of the browser window, select from the pull-down menu (i.e., the button directly above the Constrain label) either '4x6' or '4x6 Portrait'. Then, using your mouse cursor, mouse-over the image and when the Cross-Hairs are over the upper left-hand corner of the portion of the image you wish to print, click and drag from the left to the right in a downwardly diagonal motion, releasing the click at the end of the image selection.
  9. Click the 'Crop' button.
  10. From the Menu Bar, select 'File: Print', select your options, then select 'Print'.
  11. This selection, revealed in the iPhoto window will now print as a borderless, 4x6 print.
I hope this information allows you to resolve this issue. If you need further assistance,
please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to
rate this post....thanks!
Apr 21, 2009 | Canon Pixma MP500 All-In-One InkJet...
MP600 with Mac OS X - no borderless printing option?
I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
Jan 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Borderless printing kodak 5500, clear coating business cards
The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
  1. Click File , then Page Setup .
  2. In the Page Setup dialog box, click the Paper tab.
  3. Under Paper Size, select the appropriate borderless paper size.
To select borderless printing in the printer driver, follow the steps below.
  1. In the application, click File , and then click Print .
  2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
  3. Select the appropriate borderless paper size.
HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
Nov 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson R1800 prints do not lay out on paper correctly; off center
But goal is to have a borderless printout right? when you go to page setup and choose paper sizes when you go to letter size, does it have a slider for letter- borderless? and when you go to file print and and check the print setting/ print layout is fit to page selected?
keep me posted. Thanks!
Jul 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Novatel Art Explosion Scrapbook Factory Deluxe 4 Full Version for PC (SJWTNRS) Logo
Top Novatel Computers & Internet Experts
ray gallant
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
