On mh80cv i have yellow flame whitch smokes what to do
    Habit-Forming:
  • 156 Answers
Is this a gas fired heater? If so, something has changed. Could be your air/gas mixture got bumped and is out of wack or the gas coming into the house is dirtier than it normally should be. Let me know if you have natural gas or propane.
Posted on Sep 28, 2010
How do I get my furnace to stop smoking and make my burner flame turn blue
This is an oil heater with a wick, or an oil furnace?
Wick
If it smokes the wick is too high and the burner is not burning all the gases produced by the hot oil in the wick.
Use the wick trimming tool and then relight it. Light the wick and then lower the flame until it is blue.
Furnace
With a furnace, you need to open the front, clean out any soot and clean the spinner in the middle. You may need to regulate the air mix intake to get a blue flame. If it is yellow, you need more air.
If it's gas, you need an engineer.
Feb 01, 2016 | Heating & Cooling
I HAVE A DEN HAAN TRAWLER OIL LAMP. AM USING NON-DYED KEROSENE FROM A SERVICE STATION PUMP. HAVE TRIMMED THE WICK. WHEN LAMP GETS THE TULIP SHAPED FLAME IT IS A DULL YELLOW COLOR AND SMOKES ALOT. ANY...
You are using the wrong fuel! Center Draft lamps should use either "Low Odor Mineral Spirits" or "Kleen Heat" only. It will not smoke if the wick is level and the flame spreader is in place with the correct chimney. If you purchased it from Leihman's, ignore their recommendation for Kerosene. From experience I have found Center Draft's to smoke on Kerosene and not on Kleen Heat.
Nov 04, 2013 | Weems and Plath Den Haan Mini Trawler Oil...
Burning smell when running car ? Oil or electrical ?
open the hood and observe the smoke(if any) electrical smell will show a yellowish color with a blue/green/red yellow flame and it moves fast..oil smoke and antifreeze smoke(vapor really) will sort of "steam" off from near the area its leaking from when hot.. brake smell and clutch smell are almost the same since both use like materials for friction..keep an eye on this for potential problems and may need to move the vehicle outside so if it goes up in flame the house wont/grarage whatever//
Dec 30, 2012 | Cars & Trucks
Can the mr. heater mh80cv be converted to natural gas, and if so what do i need.thank you
Yes you can...but the manufacturer (Mr. Heater in Cleveland)stated you can find a MH80CV made for natural gas cheaper that than the cost of conversion. You can call them at 800-251-0001 if you need to hear it for yourself.
Jan 13, 2011 | Mr. Heater MH80CV
Why is my flame too big, it is making it smoke
Hi, not knowing what kind of heater you have I can only guess. If it is a central system, and the pilot flame is tall, yellow and smoking, it may have something like a cob web in the pilot tube that will need to be cleaned out. If you have a main gas valve in front of you, there is a pilot adjustment on it, it will say, and some have a small silver cap over the screw. You can take a very small flat head driver and adjust the height of the pilot, and this will take care of the problem. I have found insects that have crawled into the tip of the pilot tube and get cooked, causing a high yellow flame many times in my field of repair. Look it over good, and find the adjustment screw and give this a try. Just turn it one way or the other to see which way will raise or lower it, and hopefully this will solve your problem. Please keep me posted on the outcome.
Shastalaker7
A/C, & Heating Contractor
PS, you want a nice small blue flame with a slight yellow tip, so turn it down. If it stays the same in any direction, you will need to remove the pilot tube and clean the end out.
Jan 04, 2011 | Heating & Cooling
I turned my propane fireplace on and it set my smoke alarm off. We have lived here for three years and never had this problem before. Please advise.
check to see if the flame is pure blue. if not you have incomplete combustion letting CO or CO2 into the room. The flame will look yellow if this is the case. An orange flame indicates dust and dirt around the burner assembly. If it is yellow, the should be 1-2 set screws on the back of the burner assembly that will let you adjust the primary air being mixed with the propane.Adjust until you get blue flame and tighten set screws.
Dec 05, 2009 | Vanguard International Blue Flame - Large...
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
My Dyna GLo kerosene heater has excessive smoke and yellow flame
I'm wondering the same
Should a duraheat, etc., cylindrical convetion heater's flame be bright yellow, blue , or what? With the old wick the flame was blue, with the catalytic converter glowing red hot. Now with the new wick, I can't even see the CC, because the flame burns a bright yellow. Also I have to really fine tune it now. A wee bit too high, I get smoke and soot. A wee bit too low, same...smoke and possibly flame out.
Feb 24, 2009 | Heating & Cooling
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
